Intake Options
Old May 10, 2005 | 11:06 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Intake Options
hey guys, whats up.
I plan on doing a small build up on my TBI powered 305.
Heres the plan, gonna get a small cam, a few notches bigger than an RV cam, and put my set of 081s on for the heads. The one thing I need some advice on, is what type of intake.
I've heard hi-rises don't go well with TBI, I don't really need one since my power band only pulls to around 5200. Can't remember if TBIs work well with dual or single plain intakes.
I'm thining of going with an edelbrock Performer or Performer RPM, or maybe even a weiand stealth. LMK what you guys think would be best to go with.
Also, I have a friend who did a similar build up, with some minor chip work, its pretty mean. just wanted to let you know, that I already know that I'm not gonna get through this W/O some tuning. This thread isn't about the computer trouble, its about the intake, just keep that in mind. I'm prepared to deal with the chip work.
thanks for the help,
Kyle
Old May 11, 2005 | 06:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I run a single plane on mine. We can get into a discussion of theory about why, if you want. But IMHO single plane is the way to go.
Old May 11, 2005 | 07:18 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
like an Eddy Torker or somthing? a low rise single plain. I can get a Weiand Xcelerator for pretty cheap.
Kyle
Old May 11, 2005 | 07:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes something along those lines. If you can, get plenum volume information from the manufactures. You want a lot of plenum volume.
FWIW, I am running a Wieand Team-G low-rise singleplane.
Old May 11, 2005 | 07:29 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
i've never seen a team G low rise. I think i'm gonna go with the X-CElerator. my buddy has one he says he will trade for my performer.
lets hear a little about why single plains are better for TBIs.
Old May 11, 2005 | 07:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
It has to do with plenum volume, it also allows all the cyl's to pull from both throttle bores, instead of 4 pulling from one, and 4 pulling from the other. Also, since the fueling is not dependant on the vacume signal like a carb is, you don't have the low RPM, and idle issues that are normaly associated with a single plane.
Added bonus for the day:
This thread is old, this is the thread that got my project started, and got me into PROM tuning. ;-) good tech in it.
https://www.thirdgen.org/techbb2/sho...highlight=7525
Old May 11, 2005 | 11:27 AM
Ronny's Avatar
Q: instead of 4 pulling from one, and 4 pulling from the other.
my divider on the Holley Projection dual appears to be low enough to allow some flow of fuel across it? maybe 80% from "dedicated injector" and contribution of 20% from injector serving other cylinder bank? now keep in mind when the butterfly is 25% open that injecto(s) is spraying all over butterfly/shaft and i am uncerrtain how the fuel distribution ends up to be(EGT?). the Edelbrock dedicated TBI manifold. is it a single plane or dual plane?. i thought i read once that the performer carb unit is similar to the Edelbrock TBI? dual plane. with dreduded height on divider. or if you use carb manifold you could reduce its height? why would Edel and Holley not use a single plane base and configure it for dedicated TBI applications? i had 2 seasons of use with Accellerator(xram'd) and i believe the dual plane with longer runners runs better. but that may be partly due to xram adaptation not being the best engineered !
Old May 11, 2005 | 11:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
There is a lot of question there Ronny
I can possibly answer a few, some I don't have a good answer for. I like you, am always trying to learn more!
1) Why holley/edelbrok use a dual plane. I would imagine that part of this, is who they are selling to. I would image a large majority of their customers, are running basicly stock motors, and don't have the ability to tune a chip. going to the single plane, I had to make DRASTIC changes to AE and the VE tables (the AE being VERY major). Running a stock chip, and changing nothing, but going to a single plane, I would image you would get a lean back fire on throttle tip in, and probably knock in the upper end. (again, judging on teh changes I made in my chip). I doubt that they are trying to make the 'best', but instead they are trying to make something, that people will get a bit of a power increase, and will feel good about their purchase.
For tech on the rest, this thread is very good.
https://www.thirdgen.org/techbb2/sho...hreadid=216373
There is some very good info, talking about injector height above the plenum floor, plenum volume, etc. also the advantages to drawing from both bores.
Old May 11, 2005 | 12:09 PM
Ronny's Avatar
as usual. that makes sense. i am "assuming" these intakes used on mod cars. not often the case.
POI
i ran the single plane on stock 'puter' stock chip with mods listed phase 1. lean backfire you bet! with backfire, and some AE invoked with gas pedal it caught, and laid some rubber. other drivers thought i was an idiot. i was till the 7747 came in mail.
RedLeader289
Jan 22, 2016 03:05 PM
92projectcamaro
Jan 18, 2016 08:00 AM
angel2794
Sep 8, 2015 06:22 PM
InfinityShade
Sep 5, 2015 06:38 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
