v6 goveners
Old Jul 23, 2001 | 09:34 PM
V6camaroman's Avatar
v6 goveners
is it true that the 2.8 has a govener and if so how can i take it off
Old Jul 23, 2001 | 10:30 PM
HIX5000's Avatar
Yes it's true, I believe it's programed into the ecm. So you would have to burn your own chip to change it.
Old Jul 24, 2001 | 12:10 AM
AntiVTEC's Avatar
The 2.8 is governed? The heck... to what speed?
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Jul 24, 2001 | 02:49 AM
nothingssafe's Avatar
Car: 86 TA
the V6 has a govenor? at what speed? 1 have had mine to 120+(115 speedo) and nothing has happened. at what speed?
1988 Camaro
2.8 with T5
Stock for now
http://www.nothingssafe.com
Old Jul 24, 2001 | 03:04 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I heard if you replace the chip the governor goes away, and i think its at 118 or so. Dont quote me though
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Jul 24, 2001 | 03:11 AM
Car: 86 TA
1988 Camaro
2.8 with T5
Stock for now
Old Jul 24, 2001 | 06:41 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
well i maxxed mine out at 115 a few times and the govenor shut my engine off............. (but i have a 3.1)
Slayer of the following:
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Old Jul 24, 2001 | 09:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My max has been 137 mph (paced with a VW turbo Passat), and my engine wasn't shutting down- but I had (and still have) my ADS computer chip in, not the GM one.
You can axe the governor by eliminating the signal to the computer. For pre-88 guys, this is great, because our speedometers will still work. For you 88-up guys that have electronic (yes, with an analog needle) speedometers, you'll lose your speedometer.
The VSS on pre-88 cars is a yellow box located at the back of the speedometer. A regular speedo cable connects the tailshaft of the transmission to the speedometer. The VSS then "reads" the speedometer, and sends pulses down a wire to the computer. If you put a switch on that VSS output wire, between the VSS and computer, you can kill the governor. Just flip the switch to "off" when you're going for speed, and the computer won't know how fast you're going. You'll also set computer's error code for a bad VSS sensor... but that's alright.
For 88-up guys, you've all got electronic speedometers, even though (before someone asks) you've got a regular needle. Your VSS's are located in the tailshaft of the transmission- you've got no speedometer cable. The VSS signal drives the computer, and the computer drives the speedometer. You can still wipe out the governor though; just put the switch on the VSS line- but your speedometer will die. Then you just need a CB radio and get yourself paced!
[edit] I take no responsibility for your actions, this is for info only, etc etc
[This message has been edited by TomP (edited July 24, 2001).]
Old Jul 24, 2001 | 10:31 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
What year did they start putting in the goveners?
Rob
Old Jul 24, 2001 | 11:00 AM
Blade3001's Avatar
My old 82 V6 Camaro would cut at 160km/hr. It didn't have an ECM so it's a complete mystery on how. Most early Canadian (Pre-FI) or other exported V6 F-bodys don't have computers like the US one, but do have a very scaled down version which is porobably what cuts it out.
Old Jul 24, 2001 | 04:09 PM
86Chicken's Avatar
My 86 Bird has the E-Speedo (VSS in tailshaft). Might have only been auto Birds in 86 that got the E-speedo. I think Camaros got them 88/89 but I am not sure.
My $.02
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Old Jul 24, 2001 | 04:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dale, are you sure nobody swapped clusters & sensors on you? My '86 (2.8, automatic) has the mechanical speedo- and the tailshaft VSS isn't mentioned in my 1986 GM service book.
Old Jul 24, 2001 | 08:08 PM
HIX5000's Avatar
My engine gets cut out from under me at 115mph.
Old Jul 25, 2001 | 12:46 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Only because of the danger of a tire coming apart,,,, if you get Z rated tires on a 4th generation Camaro,,, the governer is taken off the car and you can go any speed straight from GM
Old Jul 26, 2001 | 10:25 AM
86Chicken's Avatar
TomP: Nope, my cluster/VSS is all vintage 86. My aunt was the previous owner and she is not the car-upgrading/gear-head type
My GM service manual does mention the two VSS styles in it, if the pages are the same, check page 8A-201-11 figure b. This is Electrical Diagnosis-Component Data-Component Location Views shows the Tailshaft style and 8A-33-1 starts the section on the Tailshaft VSS.
I saw the mech-type in the book before but now I can't find it.
Hope this clears things up!
Dale
Old Jul 26, 2001 | 10:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow! I guess I didn't check my GM book that closely, then! I'll bring these page #'s home tonight & check them out... weird. Hey, was your car maybe made for California, or Canada, and it had something to do with emissions?
Old Jul 26, 2001 | 10:37 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Firebirds had electric speedos, Camaros had mechanical. Camaros didn't get electric speedos until 90. Firebirds had them from 85 or 86. My old firebird (86) had an electric speedo. My 85 IROC & 86 Sport coupe both have mechanical.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 26, 2001 | 12:34 PM
fiream's Avatar
Engine: 400HP 350
So what your saying is that my 83 Firebird dosen't have a govener.
Chevy 2.8L, k&n filter lid, Headers Soon!!!
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Jul 26, 2001 | 01:15 PM
86Chicken's Avatar
My Bird was made IN Calif but nothing in the RPOs say it got any special treatment. Could have been that the Calif. cars got different stuff. I know they got different paint jobs - crappy clear coat that doesn't stick.
Dale
Old Jul 26, 2001 | 02:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jim, my 1986 Firebird does have a mechanical speedometer- trust me, I've dropped the trans on it. I've held the speedo cable in my hands.
Next time I'm at a junkyard, I'll dive under some 86 Firebirds, and see what they've got.
Old Jul 27, 2001 | 10:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ah HA! We're all right! Thanks for the insight, Dale & Jim, here's the deal:
Firebirds with either the "full gauges" cluster or the "digital" cluster had their VSS in the tranny.
Firebirds with the "indicator" cluster (idiot lights) had the VSS in the back of the mechanical speedo. Dale, that's GM manual page # 8A-33-4 , and the circuit op is described on the next page, 8A-33-5.
Azrael91966669
Jun 22, 2010 04:06 AM
Crazy 84 Z28
Jul 8, 2007 04:51 PM
Luther6704
Jun 23, 2006 05:35 AM
rumpilstiltskin
Jun 4, 2003 06:57 PM
84blackbeast
Dec 5, 2001 07:26 PM
