stock compression and piston volume
Old Nov 21, 2003 | 04:46 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
does anyone know what the stock piston dish volume and compression is for an 87 350 truck engine(TBI)? i'm starting to rebuild one but i don't know what i need to do to get about 9.5:1 with 58cc heads.
it looked like the deck was at least .060 or .080. if i had it decked, with 58cc pistons, and a .042" thick gasket what would the diston dish have to be?
Old Nov 21, 2003 | 05:55 PM
Damon's Avatar
Most stock pistons of that era had about 12cc worth of dish to them.
With that head gasket, .025 piston deck height (measure at the true top-not down in the dish), 12cc dished pistons (30-overbore, given that you are doing a complete rebuild), assuming 9.5cc for the .042" head gasket, and 58cc combustion chambers you will be at 9.58:1.
An alternative way to go would be to use pistons with an 18cc dish, .010 piston deck height and a thinner .028" GMPP head gasket (6.5cc). That would put you at an almost identical 9.6:1.
Old Nov 21, 2003 | 06:44 PM
Vader's Avatar
I've measured up to 14cc on 350 dished pistons with four valve reliefs and the beveled shoulder around the top ring land. 12 is a safe number for general argument's sake - not to start any arguments...
Genopsyde
Oct 7, 2015 08:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
