stock radio wiring
Old Mar 22, 2004 | 09:16 PM
jusalx16's Avatar
stock radio wiring
so yeah my radio is being a freak
apparently the previous owners of my car took out the stock radio and put in a new one, then when they sold it, replaced it with a delco radio - only what appears to be from a 94 - 95. they cut all the wires in the back and rehooked them up to the stock, so there's little blue plastic cover things on them all...
but there's a purple wire that's cut in two, and there's an orange wire with a black stripe on it that comes into the car, but there's no room to put it so it just hangs. all the other wires seem to be plugged in and intact...
so whenever i get into my car, the clock always says 12:00, and the radio is always on 1400am. i change it to whatever, then when i get to where im going and turn off the car, after about 30 seconds the radio loses it's memory and goes back to 12:00 and 1400am whenever i turn it back on. is the orange/black wire the memory wire, or is the purple one? i've already spliced the purple and attached it back to rest of it coming out of the radio but that did nothing. someone help...
Old Mar 22, 2004 | 09:44 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
yes the orange wire is the constant +12 volts and that should be connected to the radio's memory wire or battery wire
Old Mar 23, 2004 | 09:13 PM
jusalx16's Avatar
well i tried that but the radio stays on when i turn off the ignition...
Old Mar 26, 2004 | 09:55 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
If you haven't worked it out by now, go to www.installdr.com and you'll find wiring info--all the colors and where they go.
Old Mar 27, 2004 | 09:49 PM
jusalx16's Avatar
awesome. thanks =)
Old Mar 28, 2004 | 07:47 PM
LAFireboyd's Avatar
from the install dr.
To save you a few steps, here's the wiring chart for 1982-1988 cars from the install dr. I had to change size and resolution quite a bit to add this image, so I hope it's still legible.
Old Mar 28, 2004 | 07:48 PM
LAFireboyd's Avatar
cool, came out good, lol
Ok, that worked, lol, so here's the chart for 1989 and later.
Old Mar 28, 2004 | 07:49 PM
LAFireboyd's Avatar
oops, lol
I clicked too soon! Let's try again, lol.
Old Mar 28, 2004 | 07:51 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the radio is staying on because u arent wiring it correctly, the YELLOW wire, needs to connect to the ignition power wire on the radio, and the ORANGE wire needs to connect to the battery or memory wire of the radio.
Old Mar 30, 2004 | 05:45 PM
jusalx16's Avatar
okay i found out what the problem was...
a previous owner of my car installed an aftermarket alarm system... xcalibur... and that big red wire was connected to where the orange wire is supposed to go (which is the battery wire)
so i just unplugged the red wire from underneath the dash and now the memory works. freaking retarded previous owner~
but thanks guys for your help ! now i have a clock in my car and i no longer need to pull out my cell phone to know the time... and manually search for stations
you all rock
Old Apr 16, 2004 | 02:57 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
hey i know your pain my cars previous owner wasnt so smart and i guess when he made the car carbed and removed the need for a comp he started cutting random wires... everytime i look somewhere i find a new color of cut wire
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZsTransAm
Aug 11, 2015 07:30 PM
