Mobil 1 ,Royal Purple ,Redline ,Amsoil ????
Old Sep 11, 2002 | 09:26 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Which Brand of Syn for motor? I've used mobil in my rear and it whined a little with the additive. I put the RP in there witht he additive and its quiet as heck. so what to use in the motor?
Old Sep 11, 2002 | 09:30 AM
ronterry's Avatar
Car: '94 Corvette
Mobile One, Cause I can buy it local (today)....
Ron
Old Sep 11, 2002 | 09:35 AM
Parrydise7's Avatar
I've been told that Redline is the best, but then it is also the priciest.
Old Sep 11, 2002 | 10:17 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've been using Mobil 1, but I'll be most likely switching to Amsoil, since my car sits a lot.
Old Sep 11, 2002 | 11:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Amsoil's my brew of choice. It's in my rear and it makes no noise. Just waiting now for my oil change to come up so i can put my amsoil in the engine.
ede's Avatar
ede
i believe given my choice i'd run amsoil, but it's hard for me to find and i don't do the on line ordering thing, so i usually run mobil 1 synthetic and pennzoil for dino oil.
Old Sep 11, 2002 | 02:27 PM
86SCBNJ's Avatar
Amsoil, shipping really doesn't take that long....... I buy it in bulk (case) and use it in all my vehicles...... When u buy it in bulk, u have enough for the whole year.
Old Sep 11, 2002 | 02:38 PM
Mericet's Avatar
Amsoil
Old Sep 11, 2002 | 04:55 PM
Fast3rdGen's Avatar
amsoil everything from bumper to bumper, better motor oil, better coolant that works better than royal purple or redline additives, trans fluid and gear lube in the rear. and amsoil filters.
Old Sep 12, 2002 | 08:05 AM
Damon's Avatar
I'm an Amsoil dealer (just to get the discounts) and it's decent stuff. Amosoil says it's better than Mobil 1, but who the heck really knows? Both of them are far better than you will ever need them to be.
I like running extended oil change intervals on my daily beaters. Good quality synthetic stuff lets that happen without trashing the motor. Back before I went synthetic I was changing oil every 3000 miles (like a good little consumer sheep). I was changing oil on SOMTHING every weekend! Since going to Amsoil I bump that up to about 10,000 (they say I can go longer but I'm the nervous type). I've got about 70,000 miles on 3 vehicles, both new and really old, doing this routine with no problems to report at all.
Old Sep 12, 2002 | 08:31 AM
86IROC350NY's Avatar
Quote form Mark shields
What do you mean? My car sits a lot too and I have noticed that my oil (mobil 1) now leaks a bit through the valve covers. Is it the Mobil one or what? Maybe I just need new vc gaskets.
--Dan
And DAMON...can i buy some amsoil from you since you're a dealer and all. My oil change is about due.
--Dan
Old Sep 12, 2002 | 09:16 AM
Vader's Avatar
I've got a '96 with 4,100 miles on it, so it sits a lot. With Mobil 1 15W50, I have no leakage issues. Ditto on the '86 with 47,000 miles, and all the other vehicles with various mileage that sit for extended periods. I don't believe that leakage can be blamed on the lubricant. Even kerosene, JP4, and all its derivatives can be kept in a container that is properly sealed, and that stuff will wick through almost anything.
Old Sep 12, 2002 | 09:58 AM
Car: 99 Formula
Axle/Gears: 342
So, it's ok to use Mobil 1 if the car sits. Cause mine isn't driven now from Sept to Dec, so that is 4 months. I'll just stick with the MObil 1 if that is no big deal.
Old Sep 12, 2002 | 09:45 PM
17camaro83's Avatar
I like royal purple, I put that in a friend of mine's car it was a dodge stealth v6 dohc non turbo and you felt the difference cuz we put it in the engine and transmission, less friction, more power, nice stuff the engine reved up smoother and the idle was good, so either the oil is awesome or his engine sucked
Old Sep 13, 2002 | 07:39 AM
Car: 99 Formula
Axle/Gears: 342
hmmm, I can't really see it making a diff that you can feel.
Old Sep 13, 2002 | 10:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
hot rod mag just had an article on dino juice vs. synth. bottom line - synth freed up 10 hp.
Old Sep 13, 2002 | 11:08 AM
Vader's Avatar
SLP did a similar dyno test and got 9.8 HP at the rear wheels simply by changing from clean (new) mineral oil to clean synthetic.
In addition, changing to synthetic along the entire driveline yielded an overall net increase of over 16 HP at the rear wheels. There's no sdoubt the less friction = more power. There is also no doubt among those of us who have been deep into a synthetic engine after extended mileage that the decreased friction is apparent on the micrometers and telescope gauges. I'm a believer.
I also feel that Amsoil has been at the forefront in synthetic lubrication for vehicles, but Mobil has made some recent improvements that nearly erase any difference in performancec of the synthetics. It's sad for Amsoil that their distribution system is not better, since their sales could be significant with proper advertisement and distribution. Maybe some day.
Old Sep 13, 2002 | 11:18 AM
Car: 99 Formula
Axle/Gears: 342
In addition, changing to synthetic along the entire driveline yielded an overall net increase of over 16 HP at the rear wheels. There's no sdoubt the less friction = more power. There .
Wow, 16hp at the wheels.
Old Jun 23, 2003 | 03:42 AM
25THRSS's Avatar
What brand of oil were they using for the tests?
Old Jun 23, 2003 | 06:17 AM
sorch60's Avatar
Is there any downfall to switching to synthetic after using regular oil for the past 20 years?
Old Jun 23, 2003 | 08:45 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
some seals will leak slightly
after going to some of the thinner Syns (like 5-30 M1).
I think the mag tests used Royal Purple and got ~10hp.
I think SLP uses Redline.
Old Jun 25, 2003 | 03:03 PM
17camaro83's Avatar
we also did a tune up. iridum spark plugs, new intake manifold, royal purple (the engine did sound smoother)
Old Jun 25, 2003 | 03:17 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I have this same question 148K on motor earlier in posts people were saying could create leaks because of less friction, leaks in cylinders by the rings would probably be insignificant, I don't see how it would make valve covers, or motor pans leak. Anybody have any real knowledge on this subject of an older engine switching over late in life?
Old Jun 25, 2003 | 05:32 PM
25THRSS's Avatar
It won't hurt anything. Just go with synthetics next oil change.
Old Jun 25, 2003 | 08:19 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
We use Redline in our Spitfire, though we use valvoline mineral oil on break in. Redline significantly reduces oil temp at road racing speed and gives marginally more power. It's 8 bucks a quart and I would definately not use it on a streetcar. Redline has always given us asesome protection under race conditions.
On a streetcar that you plan to keep for awhile, I recommend Valvoline's Durablend, it's a mix of synthetic and petroleum oil. It's a good balance of better protection and good cost.
On a side note, we just started using Redline shock resistant gear lube in the Spitfire's trans and rearend. It also gives more rear wheel power and better protection.
I didn't read any of the previous posts cause there are too many, so if I repeated anyone, my bad.
Old Jun 25, 2003 | 08:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Okay, I'll chime in.
None of the synthetic companies hesitate comparing their product's performance against petroleum lubes. AMSOIL is willing to publish test results comparing their products to the other guys' synthetics.
That tell you anything?
Old Jun 25, 2003 | 10:49 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Mobil 1 is great. I will say though that an engine builder I know thinks that RP is the best and has seen dyno proven HP gains to back up his thoughts.
Old Jun 26, 2003 | 12:35 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
redline or amsoil would be my picks
have heard nothing but good about them
only thing I don't like is I can't find them local and they cost money
well lots of money
Old Jun 26, 2003 | 03:14 AM
BORLAZ06's Avatar
I'd like to know too if synthetic will create leaks in an old motor (152k). I would definately change over if it doesnt create leaks in my vehicle. Anyone know for sure if it will? Cuz my oil pressure can't take the laughing gas. lol.
Old Jun 26, 2003 | 04:30 AM
Enkil's Avatar
From what I understand, synthetic does not create leaks. It just finds leaks that were already there.
Mineral oil forms deposits and what-not that might fill in these leaks, plugging them up. However synthetics do a very good job at cleaning your engine out, thus removing the plugs, and making it seem like the synthetic oil caused your engine to leak.
Old Jun 26, 2003 | 04:43 AM
Administrator
I think I experienced that. But to just not leak I would have rather stayed with regular oil.
Old Jun 26, 2003 | 08:55 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I think I agree with this. I just fixed a front tranny seal thats been leaking for awhile, was **** enough to crawl under my car and clean all old oil deposits off the bottom. I don't think I want to risk another leak. Another 20K or so I will have to rebuild then after break in I will use synthetic. For now I'll sacrifice a little friction for peace of mind.
Old Feb 8, 2009 | 01:18 AM
SilentBobZ28's Avatar
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
Re: Mobil 1 ,Royal Purple ,Redline ,Amsoil ????
Amsoil makes a good detergent that you run your older engine with right before you change your oil. I did this on our farm truck before switching to AM10-40. There was literally ***** of gunk that was coming out with the pennsoil that was draining out of the motor. This was a 87 2x4 22r powered yota with 220k on the clock. It probably gets driven around an hour or two a day on the farm so dependability is key. Afterwards the truck didn't smoke anymore right after startup. Still no oil leaks and burns no oil. The heads have never been off this motor either. Now it has around 300k on it and keeps on ticking.
Old Feb 8, 2009 | 03:53 PM
Shinobi'sZ's Avatar
I have used Amsoil, Mobil 1, Redline, Royal Purple, and am now using Shell Rotella T Full Synthetic 5-40w. I believe is still has zinc in it which a lot of oils have removed from the formulation for emmissions...but some Diesel Oils still have it.
Haven't seen the Amsoil high temp sheer comparsion between these two oils.
Old Feb 17, 2009 | 04:13 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I have used Mobil 1 on the rear axle, transmission, engine and used Mobil 1 grease for my Camaro since 1993 when I got it. Never had a problem with it. Btw, the car had 64,000 miles when I got it. Now 120000 miles+.
Hotrodboba400
Dec 10, 2019 07:07 PM
3rd gen money
Oct 11, 2019 09:57 PM
school boy
Oct 22, 2015 11:47 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
