Stripped Bolts
Old Jul 24, 2003 | 04:47 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Stripped Bolts
I removed all my seatbelts just fine, except the two front torque bolts on the passenger side are completly stripped. So I cut them up to get the seat belts out.
Now I have the carpet removed and everything, but there are still bolts stuck in the holes making it impossible to put new seatbelts in.
I need some serious advice here.
Sorry about the picture quality, hopefully you can understand what I am describing.
Old Jul 24, 2003 | 09:01 PM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
Best bet is to just cut them. Go slow with a cutting tool or a dremel. It will take you a while but they will finally come off.
Old Jul 25, 2003 | 02:02 AM
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
They are all ready pretty cut up, now they are just stuck.'
I got one off, the bolt closest to the console.
Old Jul 25, 2003 | 06:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Flood it with penetrate for a coupe of days, then give it another try. If necessary, have someone weld a nut to the stub (wouldn't take a sec) so that you can use a socket.
JamesC
Old Jul 25, 2003 | 04:09 PM
MFaulkner's Avatar
Car: 90 Formula
craftsman sells a set of easy-outs that fit on the outside of a bolt/stud like a socket. Maybe worth a try. I like to give stuck bolts a dose of the Universal Bolt Remover, aka a swift rap with the ballpien. if you don't go too crazy and damage things, it can really do the job
Old Jul 25, 2003 | 04:43 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
corrett me if im wrong, but isnt the outer front seat belt bolt attachment metal attached into the frame with yet another bolt?
Old Jul 25, 2003 | 05:03 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The front seatbelt on the tranny tunnel has a plate behind the bolt. You Might beable to turn that plate if it isnt tack welded on.
You could possibly gring the bolt head square and use a adjustable wrench to turn it. Use a dremel with a steel cutting aruger.
I know for sure the rear seatbelts on the driveshaft tunnel are held on with a big nut. The the seatbelt retractor is bolted onto the frame, so if its stuck your gonna have a hard time with it.
Old Jul 25, 2003 | 05:31 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
id try vise grips, get them on there very tight. i bet u had a hard time sawin those bolts, i had to saw 2 of one of my cars, took me almost 30 minutes and 5 sawzall blades...PER BOLT!!:lala:
Old Jul 25, 2003 | 09:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
3 options.
1.. attempt to turn it as is...
..........put a pair of vice grips on it
..........cut a slit and use a tool.
..........drill it out and use a easy out.
..........flatten two edges and put a wrench on it
..........weld a nut and turn
2. break whats bonding it to itself
..........soak in oil
..........heat with torch
..........smack it with a hammer or impact.
3. cut it out.
..........drill a hole oversize until its nothing but the threads.. then run a tap thru it.
.......... cut the head off and slide it out the other way.
.......... cut out around it
Old Jul 26, 2003 | 09:39 PM
Tyler-88's Avatar
if its stuck in there, what i would do is take a chisel and a hammer and smoke the side of the bolt so it slowly unthreads and comes out. get your buddy with a welder to weld a nut to the top of the stripped bolt and just use a wrench to get it out. or i would cut the bolt flush, and drill a hole in it. you can buy these things that are hexed so you can put a wrench on them. i cant remember what their called, but their like long skinny tapered bolts that have a large backwards thread on them and they slide into the hole you drilled into the bolt and you use a wrench to unbolt them. thats almost the best i can do do describe how to do it. hope this helps.
Old Jul 27, 2003 | 02:25 AM
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Thanks a lot.
You have no idea how much I appreciated your input. This was the tiniest of problems, but was holding up my project.
Old Jul 27, 2003 | 03:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
thoes are called easy outs......
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 07:28 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
