Replacing the TV cable?
Old Apr 27, 2002 | 03:32 PM
IROCKER's Avatar
The little plastic end thing (that attaches to the throttle lever) broke. Does someone know if you can get the plastic end piece or do I have to replace the whole cable?!? If so, how do I replace the cable? Is it hard?
Old Apr 27, 2002 | 05:12 PM
blk91z28's Avatar
Your going to have to replace to whole t.v. cable.Its easy to do its only one 10mm bolt that holds it down to transmission. I broke off that plastic piece that mounted to the trottle body as well not knowing how to take it off and as a temp fix I heated up a peice of a coat hanger and melted it trew the plastic peice that I broke then i bent it around the metel peice that the plastic peice used to be mounted to. Then i adjusted the T.V. cable and it worked perfect until Iwas able to afford a new T.V. cable.I know this sound kinda crazy but I had to have my car on the road. Hope this kinda helps you out.
Old Apr 27, 2002 | 05:41 PM
IROCKER's Avatar
Thank you...Well if I have to buy a new cable then I'll do it...so it's a easy fix? Is the cable hard to feed through at all? I'm assuming you just reroute it through where the other one is (around the distributor and down to the passenger side of the tranny) and it's just one bolt? That sound pretty easy.
Old Apr 27, 2002 | 10:32 PM
Joshua Leslie's Avatar
yeah, I had the same problem, its sorta PITA with it in the car.
There is little to no room, so I hope you have a small ratchet and even smalle hands.
other than the space issue, its real easy to do.
Old Apr 28, 2002 | 04:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Its not very hard to replace, but the only places I know where you can get a new one is either the junk yard or the dealer. I dont think autozone sells those. I would look around at the junk yard first because i had to get my shifter cable from the dealer and it was about 60 bucks. GM is sure proud of their replacement parts...
Old Apr 28, 2002 | 05:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
same problme on the 84 Z28, i used a white zip tie, wrapped it arund the broken connector and the nipple on the carb throttle shaft plate and its fixed now
now to find out how to properly adjust cable, i am losing my 2-3 upshift, sliiiiiiipp may be too late..
anyone with info ? or ?
Old Apr 28, 2002 | 06:21 PM
blk91z28's Avatar
If you take the cross member off and let the tail shaft drop down a little bit and use the box end of the wrench it makes it alot easier to get to that bolt.Its kinda a pain in the a$$ getting the cable connected to the that spring loaded valve in the thight spot you have to work with but its not anything to worry about. It alot easier if you have a person pulling on the cable after you get it connected to the valve.
Old Apr 28, 2002 | 07:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i just found transfixleo's post on how to adjust tv cable and i ran out to the Z and did it and test drove it and its doing good, better, wil test drive longer tommorrow,m am low on fuel right now and to lazy to go pump in more tonight, did enough today..
time to eat now, for once before i get down to 140.. :S
thanks~!
Old Apr 28, 2002 | 09:04 PM
Nordbert's Avatar
You can buy just the cable end. It just snaps over the cable. I think FitZall makes them. Check with a local transmission shop.
Old Apr 28, 2002 | 09:09 PM
blk91z28's Avatar
yea thats good idea I wish i would of know about that before now.
Old Apr 28, 2002 | 09:18 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cool when my zip tie fix ever fails then i wil call nearest tans shop(35 miles away)
thanks guys
Old Apr 29, 2002 | 08:14 AM
IROCKER's Avatar
Well I ordered the cable from GM today...with my discount it's only gonna cost me $20 CDN. Not too bad...Thanks for the advice guys, hopefully I can get it installed without any issues.
Old Apr 30, 2002 | 04:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Before you install it, shoot brake cleaner (or water or SOMETHING) around the TV cable where it enters the transmission, and get rid of all the dirt. You really don't want to dump a load of oily dirty crud into the trans when you pull the TV cable out of it's grommet. What's the part # on that TV cable? Mine won't hold an adjustment anymore, and I think I need a new one.
Old May 7, 2011 | 01:01 PM
Bigbuds1's Avatar
Car: Chevy
Transmission: 350
Re: Replacing the TV cable?
I know this is an old post, but a new problem to me, and this will be my temporary fix.
Does anyone have a current GM part number for this plastic piece? Retro fix?
Buddy
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
