Holley SR on Vortec heads?
Old Apr 30, 2003 | 05:49 PM
StealthElephant's Avatar
Car: 87' Iroc
Can it be done? I know there are TPI baseplates to fit the vortec heads but does holley offer a vortec mounted SR? I was just interested because for 500$ you can get the intake/baseplate and convert your TPI with the SR...but there doesn't seem to be a SR intake to fit vortec heads....\
bleh...wrong forum...move to TPI...my bad
Old Apr 30, 2003 | 09:29 PM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
an HSR will not fit on any vortec heads. the only ones I know that will fit are TPI vortec baseplates and Mini-ram for vortec heads. I am using a mini-ram for vortecs on my fastburn motor
Old Apr 30, 2003 | 10:06 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
How is your set up doing black363irocz and what does it consist of? I only ask b/c i am hours away from completing mine! thanks
Old Apr 30, 2003 | 11:08 PM
Car: '88 IROCZ
It's a big splice of things. I've got a miniram and an aftermarket computer setup on the 363. running LS1 injectors and 52mm throttlebody. I've got 58cc Fast Burn heads, they are very nice, pleased with them, the 363 is a screamer, but it's only an 11 second car I got the miniram cause it's a solid roller motor and that was the only reasonably priced intake that can rev to 7000 rpm wihtout a problem. It's more or less a detuned race setup.
Old May 1, 2003 | 10:35 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I'll do what i should have done..email you! I don't want to hijack his thread or even just "chat" on here. Hopefully you'll email me back, if not, thats ok too. later
Old May 1, 2003 | 01:54 PM
Car: 87' Iroc
vortec/fast burn are the same thing except cast iron as opposed to alum right?
the miniram is nice...but way too expensive.....SR is like 600$ for the setup...the complete setup for miniram to convert is over like 1300$.....oh well...maybe holley will make a vortec SR in the future
Old May 1, 2003 | 02:53 PM
Car: '88 IROCZ
Fast burns are basically vortec heads, with a special design fast burn chamber that reduces octane sensitivity by completely burning all fuel in the chamber. Very efficient, very good flowing, but very expensive lol. the SR is cheaper (unless you get standalone) but I bought the heads before the intake and the HSR doesn't fit vortecs and was back ordered big time when I built my motor. if Holley makes a vortec HSR, that'd be badass. I don't know why they didn't like TPIS though... vortecs are the modern head.
Old May 1, 2003 | 09:51 PM
Car: 87' Iroc
the vortec heads and regular manifolds don't fit because there is a gap right? so theoretically you could make a shim to fill in the extra space so vortecs would work with a 23 degree intake?
Old May 2, 2003 | 11:33 AM
Car: '88 IROCZ
the mounting bolt angles are completely different, and the intake port roof is higher than the manifold. if you got vortec heads, use a vortec intake, there are plenty around, including fuel injection units.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
