GM WONDERBAR
Old Apr 5, 2001 | 09:46 PM
v6-3.1's Avatar
GM WONDERBAR
I recently saw this post
"and ladies...sorry...
OK, heres the deal. I just got off the phone with my local Chevrolet dealer and you can buy one of these new for $33.70 ea. The part number DuTeau Chevrolet gave me was #14079634. I think that is a universal number used by dealers but I'm not for sure. If you want to order one of these and your dealer won't help you then give DuTeau Chevrolet a call at 402/474-2020. Those guys are really nice and will help you out. I was told it'll take about 3-4 days to get it. I hope that helps you guys out"
is the GM wonderbar the same as an aftermarket wonder bar??
PLEASE REPLY.
Old Apr 5, 2001 | 10:12 PM
Matt86Z's Avatar
For $33.70, what's the point of looking? Nobody could build and market them for that much.
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Old Apr 5, 2001 | 11:23 PM
blue91rs's Avatar
what is a wonderbar?
Old Apr 6, 2001 | 12:40 AM
92TRANSAMWS6's Avatar
The aftermarket one is supposed to be a bit beefier than the GM one. I bought the GM one through my local chevy dealer and it works just fine.
Old Apr 6, 2001 | 11:25 AM
formul8!!'s Avatar
Car: 2004 GTO
I bought mine from Global West Suspension for $45.00 shipped to Chicago. It takes a little finesse to install, but it is MUCH beefier and little heavier than the stock GM piece.
Old Apr 6, 2001 | 12:23 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You can get the wonderbar for $20.22 at GM parts direct. I think the shipping is about $9
Old Apr 6, 2001 | 04:26 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i got mine for 20 bucks even
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 6, 2001 | 05:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I paid $5.00 for mine.
Got it from a local salvage yard. Just told them it was a radiator brace.
There is actually one more left at the yard I got mine from.
If you go to the salvage yard just remember that the wonderbar only came on the IROC.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Apr 9, 2001 | 09:56 PM
84IROC's Avatar
I too got mine from the wrecking yard for the measly sum of $5
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
Old Apr 9, 2001 | 10:08 PM
Camaro_hunter_d's Avatar
Hey what does this "wonderbar" do? I have one left over from a set of Iroc sway bars and did not install it. Should I?.
Old Apr 9, 2001 | 11:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Tightens up the front end a little, supposedly helps prevent cracking around the steering box too.
Old Apr 10, 2001 | 09:33 PM
Night Hawk's Avatar
Did the GTA's come with it?
Old Apr 10, 2001 | 10:08 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
The IROC-Z's only got them.
Old Apr 17, 2001 | 01:34 PM
Mach5's Avatar
Where does this mount. This is the first that I have heard of them
Old Apr 17, 2001 | 01:43 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i was wondering the same thing. where are the connecting points on an rs model? i thinkin about gettin one but im not sure exactly will it would go.
thanks
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old Apr 17, 2001 | 03:05 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i am not 100% on this, but i saw IROC supsention, and that wonderbar bolted where the middle two front swaybar brackets where.
i could be wrong... i will let an expert answer.
Dewey 3:16
90 RS 305 TBI LO3
No Mods yet. coming soon!
90 RS 305 TBI
Old Apr 17, 2001 | 07:12 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Wonderbar
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 18, 2001 | 07:52 PM
yes they do bolt under the front sway bar bushing mounts...if that makes any sense.
Old Apr 23, 2001 | 12:18 AM
ADMZ24's Avatar
Car: 1991 Trans Am
I just installed my wonderbar last night. Peice of cake, I can feel a slight difference. I think it is worth every penny.
1991 WS6 Trans Am
Medium Green Metallic
Beechwood interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Old Apr 25, 2001 | 12:09 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Just an FYI, global west makes one that is a LOT beefier than the GM piece.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
