Spohn Adjustible "wonderbar" gets my two thumbs up!...
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Installed it this past saturday the morning of a drifting event at the track. As soon as I took it out for a test drive I could already feel a difference. The front end seemed to be noticably stiffer and the steering was more crisp then before. Once I got to the track and fully used this part to the extreme is where I noticed a big difference. The front end under extreme force stayed together and felt alot better. I highly recommend Spohns Adjustible wonder bar to anyone who needs a wonderbar.
Car: '87 Z
Engine: 355 in the works
... did you already have a wonderbar? I'm thinking about picking up the spohn piece to replace my GM one whenever their 3 point strut tower brace comes out...
Engine: Built L98
nah I never did have one before. So I dont know fully how much better it is then the stock one. But soon me and CrazyHawaiian will be comparing the stock vs. the adjustible spohn.
Car: 92 Z28
Engine: Boosted LSX
Id def. like to know if a Adj. one is better then a stock one?
What would you need to adj. a wonderbar for?
Let us know how the comparison goes.
Car: '87 Z
Spohn says it's so that you can apply preloaded tension...
Can anyone enlighten me as to what exactly that means, and how it can help performance?
Originally posted by CheezX
That would mean you bolt on the bar then adjust it to make it shorter. Which would put the bar in tension and have force pulling inwards on both frame rails.
Yeah. I just wanted to hear someone else say it first.
There's no advantage over a normal wonder bar if the bolt holes are precise. Seems like it would just increase the stresses on that weak part of the frame. It may have an affect on the fatigue(life expectancy) of the frame if you preload it tighter than the force the steering box puts on it. Keeping the frame under either compression or tension instead of both could help...maybe...a bit. Or it might not. But you'd never really know.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I would agree that preloading would have questionable benefits.
The only other thing I can think of that would make the wonder bar more effective is to weld it in. That way it wouldn't rely on the bolts to keep the chassis in place during hard cornering. But I'm not even sure is this would have a measureable benefit. But in theory it would certainly stiffen the chassis up more than having it bolted on.
Anyway, just a thought.
I agree with you guys also. With all due respect to Steve and his great product line, I don't see an advantage here. You want it stiffer? Weld the thing in there. No flex...
Ed
Ed
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Originally posted by MdFormula350
adjustable just sounds so much better
It's a gimmick. Who else offers an adjustable WonderBar? Nobody. If, say, somebody DID offer an adjustable WonderBar then a potential buyer is baited into thinking that it is better. Bang - new sale. There is absolutely NO REASON that you would want to spread your frame apart or to cinch it together. In fact, I'll go out on a line and say you DO NOT want to do that. Stick with a regular aftermarket WonderBar. The stock WonderBar is flimsy. But, there is no need to invest in an aftermarket adjustable one ... unless you have a need to bite the gimmick.Tim
Some people seem to get the idea that you pull on the bar like a come-along. The instructions state to tun the adjuster one turn after the bar is mounted. With fine threads, one turn is around 1/32".
It's not a gimmick. I have had nothing but very positive feedback from everyone who has installed it. It's an option, if you don't think you want it, then get the std. bar. We've always offered multiple options on our parts, and this one is no different.
Steve
Steve
Car: '87 Z
Well Steve, I have a GM piece right now, and when your 3 point strut tower brace for TPI's comes out, I think I'll be picking up your adjustable wonderbar to go with it.
:rockon:
:rockon:
Steve is there anyplace online I can go read about this? What type of gains are possible? Or can you recommend a book or anything? I kind of understand what these guys are saying but then I kind of dont. I would like to learn more about it. Since I will be pushing the car to its limits like Revlimit, I really want to know how this piece can help me.
Thanks!
Thanks!
Car: 1991 Trans Am convertible
I have a 84 Z-28 with sfcs and a strut-tower brace . Would I recognise a difference in handling by installing the wonderbar?
My car was converted to right-hand drive because I live in Australia. I noticed that the power steering box was flexing and I had it removed and put quarter inch plate made into a box and then re-mounted the box to that. It really strengthend that area and I am very happy with the results. I have no flexing in that area. Would I still notice a difference? I do feel that it may help on making the tires last a little longer because the front end would be more stable. Am I right?
I'd like to see that right hand drive car too...kewl.
Ed
Ed
Engine: Built L98
And I'd also like to see pics of this RHD camaro O_o I was atcually considering trying this for the hell of it (yes that sounds crazy but yea I am O_o)
Thanks for the info. Will have to wait till I can get them to Australia at a good price.
Car: 1991 Chevy Camaro
Engine: Chevy 305 bored .30 over
Re: Spohn Adjustible "wonderbar" gets my two thumbs up!...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the idea is that you can put some preload into the front frame to help stiffen the steering up a little more.
Pac J
May 17, 2020 10:44 AM
