Parts for Sale 2006 Keep it Third Gen related please!
complete rear hatch motor and assymbly
Old May 15, 2005 | 03:49 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
i have a complete rear hatch motor/assymbly with all wiring and relays.. worked awesome before i pulled it.. all you have to do is bolt it in, run the ground wire and plug it into your harness and you're done..
came from a 1986 L69 IROC..
shipping weight is 8-10lbs
45$ + shipping for the whole thing takes it.. paypal accepted
send me a PM if you want it..
Old May 19, 2005 | 11:24 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
bump
Old May 22, 2005 | 12:24 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
this is a good deal.. anyone?
Old May 22, 2005 | 12:52 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
start your own thread.. not jump on some one elses.. i see you are new..
Old May 22, 2005 | 01:08 PM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
Does this come with the switch to pop the trunk release? If so, Ill do $45 shipped. Thanks, Scott.
Old May 22, 2005 | 01:46 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Re: new member
Originally posted by foward540
i/m been on from nov 2004....when did u come abord????
why do you have 2 posts then? ive been on since march 02.. but when this webiste went down in dec, my date got changed.. and yes start your own thread.. you should know better if you have been here longer than a month..
scott i do not have the little toggle switch that is mounted on the console(is that what you are asking?).. that whole piece was sold a long time ago with the console, but everything else is there.. wires, relay, wire for the ground, ect.
Old May 22, 2005 | 01:56 PM
Super_GTA's Avatar
So, This peice has the wires that connect to the consol switch? It was a push release correct? All that is missing is the switch or am I wrong. Let me know thanks, Scott.
Old May 22, 2005 | 02:44 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
no the wires that connect the switch on the console to the rear release are not included because all cars should already be wired for that, even if your car never came with that option. i had 2 cars, an 86 and a 92.. the 92 never had the option, but when i removed the console i found the plug for the switch just sitting in there not connected to anything..
so your car should already be wired, but you would need to either cut a whole for your console(super easy), so the toggle swtich can be mounted, or buy a new TOP console with the hole already there. it might be tucked back, or tied back, so look carefully.
when you take this assembly, and plug in all the wires, you should be already to go, all you need is what i stated above.
pull your top console off, and see if there is a black plug(should be 2 wires going to 1 plug) that is not connected to anything, that should be your remote hatch release.
Old May 22, 2005 | 02:50 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
complete assembly housing and everything? got pics? how much shipping to 11764, i'll take it if Super_GTA backs out.
Old May 22, 2005 | 03:02 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
yep its complete.. and worked very well when i pulled it 5 months ago.
shipping should be 12$ Via UPS to your zip code.. it weighs about 9lbs
its yours if you want it..
shoot me a PM if so, i'll let you know my paypal or make other arriangments.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
