Fuel Pump
Old Apr 29, 2002 | 06:07 PM
89Formula305's Avatar
Fuel Pump
Ok when i turn the key on i should hear the fuel pump prime, am i right?
Well i turn the key on and hear nothing, the car has been sitting without start for a couple months due to inner fender being out and no place to hold battery.
My question is, if the fuel pump is bad how difficult is it to change, is it up front or in the tank? I have a 89 formula 305 TPI.
If this is not the problem, suggestions?
Old Apr 29, 2002 | 06:25 PM
GKrazy69's Avatar
Check your fuel pump relay and make sure it's working properly.
Old Apr 29, 2002 | 08:13 PM
daverr's Avatar
fuel pump
if your sure u dont have any fuel pressure.i would check to see if u have power at the three wire connector(located above the differential).if u have power at the the plug than your pump is bad if u dont have power than i would check the fuel pump relay.
now to change the fuel pump.jack the rear of the car,place the stands on the frame not the axle.i cut the exhaust pipe just before it goes around the axle(sawzall does a perfect job),remove the muffler.support the axle and disconnect the lower shock nuts.let the axle hang.remove the muffler shields.disconnect the fuel pump wires ,and fuel lines.now here comes the fun part remove the fuel tank straps.the fuel tank filler neck is going to fight u.keep in mind that the fuel filler neck has a flexable end to it.
dave
Old Apr 29, 2002 | 08:54 PM
Thank you, now wheres the relay lol, or is it the plug above diff?
Thanks again
Old Apr 29, 2002 | 09:42 PM
Old Apr 29, 2002 | 10:01 PM
GKrazy69's Avatar
Here are the relay locations . They may not be in that order though.
Old Apr 29, 2002 | 10:06 PM
Vader's Avatar
Did someone ask where the fuel pump relay is located?
It could also be a fuel pump fuse:
Old Apr 30, 2002 | 03:14 PM
ok thank you alot, i think i know what my problem is...when i took the inner fender wells out to replace i unhooked that fuse...wow im glad it was somthing simple, im going to go out in a min to make sure that it..
Old Apr 30, 2002 | 07:41 PM
well folks i think i have some work ahead of me.....drop some exhaust, and rear end lol, sounds like fun, thanks for the help..
Old Apr 30, 2002 | 07:43 PM
but before i give up how do you check to make sure the relay is working properly?
oh and the plug that i thaught was it was on the other side of the eng comp and it went it what looked like a vaccum canister lol
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
