Harmonic Balancer
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Harmonic Balancer
Anyone know where to get the tool to press a harmonic balancer on for a reasonable price? Or maybe another component friendly way to get it done, perhapse? I saw one for like 40 some odd dollars plus s/h but thats alot for a tool that ill probably only use once.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Hey do a search ,Vader, gives a list all you need I believe is a #5 or harder bolt same size as the one in it...Put a nut on it with some washers..bingo bango the nut and washer draws it in..or you could borrow one from autozone...
Car: 91 Formula
Re: Harmonic Balancer
Car: 88 Camaro SC
Engine: SFI'd 350
many thanx... i looked for teh bolt and nut earlier but to no sucess. Now that i know what size it is, ill go out to the hardware store and see if i can find it.
Car: '86 TransAm WS6
Transmission: Custom TH700R4
NNOOOOOOOOO..............
Don't just get a bolt from the hardware store. You will want to use a Grade 8 bolt, or in a pinch, a grade 5. Grade 8's are about the strongest hardware you can readily get your hands on. You don't want to risk breaking a cheap bolt off in the crank snout.
I also reccomend getting a new balancer bolt. I like the stuff from ARP. I have heard that many of the factory fasteners are 'torque to yeild' which means that if you try to reuse them more than once, they'l break.
When I did my balancer, I used a Grade 8 I got from the local parts place. (no one has the tools for rent)
is it hard to install a harmonic balancer? i may be getting a 350 shortblock this summer and i was wondering if its to terribly hard to install one seems like it would be hard since you could mess up the timing very bad i dont know
Engine: 406
I think I paid like $16.00 for my installer/remover at autozone...Ive loaned it out about 3 times since.....have your friends pitch in, if you mess around much with motors, money well spent.
Car: 88 Camaro SC
Engine: SFI'd 350
cake... went on in like 1 minute. Only cost about $.89 dollars for the bolt and nut at the local hw store. Have it for the future too if i need it again
Transmission: 4L80E/4L80E
Personally, I use my $15 installer, which came with an assortment of snout threads and a spacer to keep from galling the balancer.
Got it a few years ago, can't remember if it was Harbor Freight or JC Whitney, but I've used it several times.
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
