Four front wheels --- Good or Bad?
Old Jun 11, 2002 | 07:05 PM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
Wanted to get some opinions on the feasability of running two "front" 16 x 8 IROC wheels on the rear of an 87 IROC to help fill out the wheel wells and gain an extra inch of overall contact width. Are there problems associated with this setup, or is it a beneficial swap? I want to keep the stock appearance, so I am not really looking to use aftermarket rims. Also, what are the pros and cons of using wheel spacers?
Thanks in advance!
Old Jun 11, 2002 | 07:51 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
there is a reason that the IROC rims have front and rear printed on them
the offset for the front and the back are different. One will rub if memory serves me correctly.
Someone else will elaborate, i am sure.
Old Jun 11, 2002 | 10:34 PM
Yes, the backspacing on fronts is 4.75", and the rears 5.25", so a difference of one half inch per side. I have only envisioned this on paper, as I have not actually taken a front off and put it on the rear to see if it would fit. What made me assume that is was possible is that a half inch is a pretty small amount to work with, combined with the fact that a couple of wrecking yard web sites have stated policies that they will not break up sets to sell fronts separately, which spawned the idea in my head that others had thought of this and were looking for a pair of fronts to stick on the back.
If there is indeed clearance problems, would it be with the fenders, or the brakes? My car has the four wheel disc brake option, if that's relevant. Thanks again!
Old Jun 12, 2002 | 12:32 AM
lasersi's Avatar
Fronts, will fit fine on the back! However rears will NOT fit on the front! I had a friend who ran four fronts on his GTA so he could rotate his tires.
Old Jun 12, 2002 | 02:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
hey Charlie's87 i just noticed you are from portland
check out http://www.cascadecrew.org
Old Jun 12, 2002 | 08:01 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Yes you can run fronts all around. It does wonders at filling up the wheelwell and doesn't change the handling characteristics at all from my experience. I've been running 4 fronts on my Formula for years without any problems.
Old Jun 15, 2002 | 08:42 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
why would having fronts on that back fill up the wheel well more?? there both 16x8
Old Jun 15, 2002 | 09:10 PM
Yes, both 16 x 8's, but the backspacing is one half inch less on the fronts, therefore they will stick out one half inch more when put on the back.
Old Jun 15, 2002 | 09:12 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
you would think so, but i am not sure
87yellowirocz
Exterior Parts Wanted
Oct 23, 2015 09:52 PM
B_Dubya
Aug 26, 2015 05:09 PM
LittleFranks
Aug 20, 2015 03:55 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
