Door Hinges
Old Jun 25, 2002 | 09:53 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Door Hinges
This may be the wrong place to post this. However, I have just finished installing 3rdgensolutions greasable hinge pins on my 88 GTA. The hardest part of the installation is grinding off the heads of the old hinge pins. The rest of the installation was a breeze. Because my hinges were not in the greatest shape, the top and bottom sections of the upper hinge were not perfectly in line, therefore, there may be some side loading on the hinges.
I greased them, and I have quiet doors which do not drag anywhere, do not rattle or squeak, and best of all, do not need to be slammed!!!!
These hinge pins are absolutely fantastic.
Kudos to Andy at www.3rdgensolutions.com .
Cheers
Richard
Old Jun 27, 2002 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Richard,
I'm seriously contemplating Andy's 'fix'. Any suggestions that would make my install easier? Were you forced to make any adjustments afterward?
JamesC
Old Jun 27, 2002 | 07:11 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
James,
Use a hoist to support the weight of the door. Do not pry on any of the hinge parts. Do get someone to help, or at least for moral support. Make sure the grease nipples face you before you tighten the hinges. Finally, do cover the trailing edge of the front fender to prevent any possibility of damage.
Absolutely no adjustments were required. The door opens and closes level.
The installation took about two hours per door, and the end results were more than worth any amount of sweating during the install. The kit provided by Andy is 100% complete, kinda unusual in this day and age.
Cheers
Richard
Old Jun 27, 2002 | 08:58 AM
JamesC's Avatar
Richard,
Could I somehow manipulate a floor jack to support the door? Did you remove the inner door panel and weather stripping at the front of the door?
JamesC
Old Jun 27, 2002 | 10:32 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
James,
I used a floor jack on the drivers door, but I had someone hold the door for the entire time I had the hinge pins out. I didn't remove the weatherstripping at the front of the door, but in hindsight it would have made the job easier. I did not remove the inner panel, I could not see any advantage to this. Just blow off the material from grinding with an air line.
I also replaced the lower pins at the same time, just be careful with the spring, it is a b**ch.
Cheers
Richard
Old Jun 27, 2002 | 11:04 AM
urbman's Avatar
I was just about to get started doing this...
Any chance you replaced this ?
Perhaps you remember the part number
Old Jun 27, 2002 | 11:25 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Ouch urbman, replaced the pins and bushings, but my tesion wheel was not damaged like that.
Sorry, cant find the part number.
Cheers
Richard
Old Jun 27, 2002 | 08:31 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have the roller and replacement pin available. But have not put it on the website, because I do not yet have the installation photos or instructions done.
Thanx,ANDYZ28
Old Jun 28, 2002 | 12:22 AM
urbman's Avatar
Thanks I'll contact you directly...
Old Jun 28, 2002 | 06:05 AM
JamesC's Avatar
Andy,
Any progress on your brake kits? I'm interested.
JamesC
Old Jun 28, 2002 | 08:59 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Originally posted by JamesC
Andy,
JamesC
Front or rear (drum-to-disc)?
Thanx,ANDYZ28
Old Jun 29, 2002 | 02:46 PM
JamesC's Avatar
Andy,
Fronts.
James
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
86IROC112
Oct 9, 2015 10:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
