Tranny mount... explitive deleted
Old Aug 28, 2002 | 01:54 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
My tranny mount went out last night at CSUN so I picked up the new Energy Suspension polyurethane mount from Autozone (lucky they were open til midnight, I didn't get out of class until 9:30)
The worst bolts to remove are the mount to the transmission bolts. I was going by the tech article on the page, and it could be different for the V6 because it specified 14 mm bolts when I found them to be 13 mm bolts. And I found it a lot easier to remove the crossmember to get to those bolts.
I would post a pic of the old mount, I can't find my digital camera's download cable. Will post it later, the rubber completely separated from the metal part.
The clunk is gone so I feel relieved about that.
EDIT: Forgot to say that made in China tools are CRAP. I probably broke every made in China tool I have getting the 13 mm bolts off!
Old Aug 29, 2002 | 12:47 AM
89V6FBIRD's Avatar
BTT, found the pic too. Crazy that I was driving around and nothing was holding the mount to the crossmember.
Attached Thumbnails Tranny mount... explitive deleted-busted-tranny-mount.jpg
Old Aug 29, 2002 | 03:51 AM
funstick's Avatar
normal for a tranny mounts to break like that
Old Aug 29, 2002 | 05:33 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
but you got those two bolts out in 1 piece, didn't you
Old Sep 3, 2002 | 12:16 AM
jwright's Avatar
how much was the tranny mount? a local shop said it would be almost 300 for the part alone.
Old Sep 3, 2002 | 01:53 AM
Ragnarok_Tyr's Avatar
I'm on tranny mount #4 myself. And the price is more like 9 bucks.
Whoever told you 300 either is retarded or needs to be reported to the BBB.
Old Sep 3, 2002 | 02:03 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Do you have a 90 to 92 5 speed? I heard that tranny mount is a dealer only part and is muy expensive!
Old Sep 3, 2002 | 11:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Guys with V8's and manual transmissions use the GM mount- same one used for automatic transmissions.
What exactly would be so special about a V6 manual tranny that it would need a special $300 mount? If the ES mount works for V8 manual trannies, it should work with our trannies. If not, send it back to Summit Racing, or sell it on ebay- it's only $20.
Old Sep 3, 2002 | 01:01 PM
Akshay's Avatar
I have 5-spd. trans. The tranny mount for the T-5 tranny is more heavy-duty compared to auto tranny mounts. This is do to the fact that manual tanny's jerk a whole lot when shifing gears.
The tranny mounts are different for a T-5 and auto trans.
This is because the crossmember is different.
It was Sunday and GM parts department were closed when my tranny mount broke. So I freaked. Tranny mount for T-5 is a dealer-item only (~$15).
So, I went to the wreck yard, got a crossmember ($16) used for auto trans. Then I went to Napa Auto and bought the auto tranny mound for $7.00.
The auto tranny cross-member and mount bolted in easily.
I should've waited for Monday for the GM parts depar. to open.
Stupid me, I spent more than I should've. But the car runs great.
Akshay
Old Sep 3, 2002 | 01:32 PM
jwright's Avatar
yeah i have a 92 5 speed, the guy said to replace the tranny mount, it was a dealer only part that was the motor and tranny mount all together. He said tahts the only way to buy it, and that you cant just buy a tranny mount.
Old Sep 3, 2002 | 02:29 PM
Akshay's Avatar
Ouch! That's weird.
How much was the whole tranny/motor mount package?
Akshay
Old Sep 3, 2002 | 03:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
But Akshay, V8 f-bodies use the auto-tranny mount on their manual transmissions!! There is no way that our V6 can abuse a trans mount more than a V8 can!!
And "technically" the trans mount is considered a third engine mount. Without the trans mount or crossmember, your engine will pivot backwards on the two front motor mounts. Thats why when you drop the transmission, you need to support the engine from below with another hydraulic jack on the oil pan (with a piece of wood between the jack and oil pan, of course).
Old Sep 3, 2002 | 04:05 PM
Akshay's Avatar
Interesting, I did not know that.
Know wonder my auto tranny mount held up well to my abusive driving.
I guess swapping the orig. cross-member to an auto tranny cross-member wasn't a bad thing after all.
Akshay
Old Sep 3, 2002 | 04:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wrote that in my first message on this thread... I knew nobody reads what I type! But I had no idea the crossmember was different- thanks! Was your original crossmember missing the center hole?
Old Sep 3, 2002 | 05:07 PM
Akshay's Avatar
I actually read what you typed earlier, but it just slipped my mind.
I realized that after I typed my message..........ssorrry.
My original cross-member had a huge hole in the center compared to the auto tranny's cross-member.
The orig. tranny mount was also big when compared to the auto tranny mount.
Akshay
Old Sep 5, 2002 | 04:24 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
yeah i had my mounts break, every time i went to the track it would fail and be in two parts, so i stopped going to autozone to buy them and went to Chandlers, i have been to the track 3 times on this one its still shifting great!
Old Sep 5, 2002 | 06:35 PM
RPS's Avatar
RPS
i have been told that the mounts were like 300 dollars, was because they were fluid filled?? WTF?
Old Sep 5, 2002 | 06:56 PM
Engine: 3.1
hmm mine were 12-15$
Old Sep 6, 2002 | 08:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
RPS, like I said before...
Old Sep 6, 2002 | 12:38 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I heard vibration is pretty bad with the poly mount. And you have to kind of break them in to get them not to vibrate as much? Can anyone elaborate on this? Where could I buy one of these?
Old Sep 6, 2002 | 12:40 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Was it hard to change them on your car? COuld you do a step by step change real quick? Just wondering..... I've never messed with anything under the car besides the fuel filter.
Old Sep 6, 2002 | 01:32 PM
Engine: 3.1
not hard at all i just used a jack to hold the tranny up while i undid the crossmember , you have to drop it to reach the tranny mount, undo the tranny mount replace with new tranny mount, raise the tranny back up and bolt crossmember back up, took me about 15-20 min each time
Old Sep 6, 2002 | 01:53 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Cool, thank you!
Old Sep 6, 2002 | 02:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Elevario, I never noticed any extra vibration when I went to the ES poly mount. I think that vibration thing is just an urban legend!
Old Sep 6, 2002 | 02:52 PM
I don't know about vibrations, but I have heard that ES recommends putting poly tranny AND motor mounts in at the same time, to prevent flexing due to the difference in stiffness between normal and poly mounts.
Old Sep 6, 2002 | 09:00 PM
89V6FBIRD's Avatar
The Polyurethane mount doesn't make more vibrations than the old one did. The car vibrates just as much... maybe it's time for new shocks... lifetime warranty, how long do they last anyway? There's about 30,000 on these shocks right now.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
