Should I get a cutout?
Old Sep 5, 2002 | 10:08 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm gonna get my exhaust done pretty soon, probably SLP ypipe and hooker catback... I was wondering, should I get a cutout or not? Is it going to help any, or is it not really worth it? Just wantin some ideas....
Old Sep 5, 2002 | 11:18 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
It'll drop 1-2 tenths off your 1/4 time.
Old Sep 6, 2002 | 11:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you got the cash, it would be nice to have, wish I had put one on.
Old Sep 6, 2002 | 04:53 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
My cutout was good for a tenth in back to back runs.
Old Sep 8, 2002 | 03:49 PM
brian89transam's Avatar
Was the .1 -.2 gains you are talking about from a cut-out in front of a cat-back exhaust system?
I know cut-outs help, but I didn't know if they would when you already have a free-flow muffler.
-Brian
Old Sep 8, 2002 | 04:07 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Yeah. I have SLP headers, cat-bypass pipes that go into a 3" Flowmaster catback. The cutout is in the I pipe in front of the rear axle.
Old Sep 8, 2002 | 09:13 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
I had them right after the headers and made over 4 tenths difference. I went from 12.82 to 12.36. My car had a single 2 1/4" pipe instead of a 3" pipe though.
Old Sep 8, 2002 | 09:49 PM
ninety1TAgta's Avatar
If you want bragging rights to a better ET go for it, if you want better day to day power than the money can be better spent elsewhere. My opinion anyway...
Old Sep 9, 2002 | 12:17 AM
I understand what you're saying about usable power. Kinda like nitrous. BUT...
A cut-out is still one of the most efficient hp parts you can buy. $35 + install for atleast 1-2 tenths quicker. It's pretty hard to beat.
Like he just said, it all depends on how much you'll use it.
-Brian
Old Sep 9, 2002 | 06:54 PM
jocww's Avatar
Car: 84z, 65 elcamino
Transmission: t5 m21
Axle/Gears: 373s 411s
what is a cutout
Old Sep 9, 2002 | 07:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A piece that lets you open up the exhaust before the muffler, easier than actually pulling the exhaust apart.
You "cut out" a piece of the exhaust pipe, install this device. Then, at the track, you remove the cap from the device, "uncorking" the exhaust. Makes it less restrictive (in most cases, anyway) and theoretically more powerful, and certainly much louder.
Old Sep 9, 2002 | 07:18 PM
SLOWS6's Avatar
would it be a good idea to put one right after the y collector?
Old Sep 9, 2002 | 07:50 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Always after the headers!!
Old Sep 9, 2002 | 08:11 PM
Idealy it would be best right after the y-pipe and before the cat, but if you're going to use it more often than just at the track, you'll probably want to put it just in front of the bend over the rear axle. It will still yeild gains. It will have a lot less vibration back there and will be quieter inside the car. Cut-outs are very popular in on 4th gen fbodies cause they're so cheap and cat-back exhaust systems are so expensive. Most 4th gen guys put em just in front of the back axle and report .1-.2 ET gains.
Also, try going to-
www.installuniversity.com
Once you get there, click on install documents on the left. Then scroll down and click on cutout explanation. They have a pretty cool location for a cutout. The video sounds awesome too. It's a great site, too bad it's almost all LS1 stuff.
Old Sep 14, 2002 | 12:41 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dont get the pull cable kind
Old Sep 14, 2002 | 01:22 AM
Administrator
Yeah I think they only make them in 2 1/4."
Old Sep 20, 2002 | 03:31 PM
383IROC's Avatar
i recently bought my camaro and have little money left over for mods. i have seen the cable style cut outs and i was wondering if it would be worth my while to make a home made cut-out out of a 3" throttle body and some exhaust pipe. would the throttle body be too restrictive?
Old Sep 20, 2002 | 04:13 PM
kfoley's Avatar
Car: '85 Z28
You can buy one from summit for $30. I doubt the one you would build would seal right. It would take a lot of work for it not to leak.
Old Feb 24, 2003 | 02:09 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i had one on my car right after i got it... took it to get it installed and told dood to put it in the Ipipe and he put it in the ypipe infront of the cat... the car sounded like crap unless i was WOT... unless it is a track only car put it in the I pipe right before the axle.. much better IMO and sounds better for a daily driver...
Old Feb 24, 2003 | 08:20 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I went with the 3 inch Summit Racing cutout....and a 3 inch McCord Power Plate (electric).....its one of the best things I've bought..I love it. It's placed in the intermediate pipe...almost underneath my back passenger seat...after the cats...my cats have been removed anyhow....here is a picture....alot of you guys have probably already seen it....
Old Feb 24, 2003 | 08:22 PM
Engine: 5.7
...the switch panel.....
Old Feb 24, 2003 | 08:25 PM
ouch! whats the point of a cut-out if its way back there after the cats???? if your car sounded bad with open "headers" (manifolds im guessing) then its cuz its stock. i have heard many upon many open headered SBCs and BBCs and usually the ones with some mods (heads, cam, intake) dont sound bad what-so-ever.
how much did that powerplate thing cost ya???
edit: $99 + $6 S&H
Old Feb 26, 2003 | 05:24 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
i have a mild 355 and runnign strait header sounded bas ***, i now have true duals, and i hope to have 2 3inch cutouts put on this summer. and by the way, its for performance, its just dumb to put it after the cat unless the cat is gutted, just my HO.
86White_T/A305
Mar 6, 2016 01:48 PM
formula_novice
Sep 5, 2015 03:58 AM
Josh 91RS
Jan 22, 2001 01:23 PM
Mike Harvey
Dec 7, 2000 02:52 PM
