Fill er up, but uh, where??
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I am going to put my new 9-bolt in sunday and I went to replace the fluid today but I cannot find the place to put the gear oil in.
In front of the pass. side axle tube, on the side of the diff. case, just above halfway up should be a square-socket plug. A 3/8 extension fits perfectly in there. Remove it, and fill the fluid JUST to where the fluid starts seeping out (on level ground).
Don't forget to put the plug back in!
hth
hth
Car: 4
Engine: 6
Transmission: 5
9-bolts are supposed to have a rubber plug in the cover... if yours doesn't have that, then fill it up with the correct amount of fluid before you put it in.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt has a rubber plug on the rear cover. Fill it up until it runs out. Capacity is posted at www.9bolt.com
Miles
Diff Solutions
Miles
Diff Solutions
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I don't see the capacity on your website. I am not in the mood to play right now. It is your website, and I understand that you want visitors, but just tell me how much freakin fluid to add. I looked there, I don't see it.
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
its at the bottom of the list on the torque spec page...
1.7qts and a bottle gm additive.
or you could just fill it till it runs back out the hole thats what i always do
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Miles
Engine: 305 TPI (LB9)
Transmission: WC T-5
and always make sure that you add a bottle of GM limited-slip differential additive when you change the fluid. Use GM only! (not sta-lube, not Castrol, etc.)
Car: 92' RS
Engine: LO3
Just GM? Nothing else? I just got some from from autozone called trax something or another. Said it can be used on GM cars.
Car: 1984 Firebird
Axle/Gears: 4.10
yes only use the gm limited slip additive, none of the cheap crap at parts stores will keep them quiet while turning, unless of course you like to hear clunking grinding noises from your car
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
No worries foney_ Sorry about the mess on my site. I'm working on a new design but just haven't had time to finish it yet
It will be layed out much better and will be easier to find information.
Miles
It will be layed out much better and will be easier to find information.Miles
