Made MAJOR progress today! Car about ready to start
Old Sep 22, 2002 | 11:05 PM
Guido's Avatar
Car: 2000 Trans Am
My friend Jerry stopped by early and woke me up today and we got started on the car. Worked till 7pm and almost ready to start the car. Have to do a little welding on my wastegate to downpipe tube but then it should be ready to start up. Going to get that breaker and wires in the garage tomorrow to get the TIG welder going (its a 220 welder)
Anyway, here are some photos! Enjoy
Old Sep 22, 2002 | 11:13 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Looking good man.
Old Sep 23, 2002 | 02:39 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Nice! Are you going to get some track times before the snow flies? I think I'm going to get back into cars after taking the summer off...
A.
Old Sep 23, 2002 | 03:03 PM
Guido's Avatar
Car: 2000 Trans Am
Well, I want to have the car ready to take to the dyno next weekend (not this coming but the one after) and as soon as its safe on the dyno then it will be off to the track for a few testing sessions. Im hoping to take the car to the thunder shootout (www.thundershootout.com) November 2nd.
So I have to have the car done, tuned and confidant it will go down the track before I drive 11 or 12 hours on an untested car.
Old Sep 23, 2002 | 08:15 PM
89Irocz23's Avatar
man thats looking good!!!
Old Sep 24, 2002 | 09:04 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Curt, I KNOW you're not going to use that stainless band clamp to hold your intake tube to the TB. ????????????
Old Sep 24, 2002 | 09:25 PM
Blown406bird's Avatar
Looks good Curt!! Cant wait to see some dyno numbers Any projections?
Old Sep 25, 2002 | 11:44 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Good luck on the dyno If you could post/email some detailed notes on initial setup (fuel & timing), those dyno noumbers, and how things changed as you get it dialed in, I'd be very interested.
A.
PS - We just got in the Southern Shootout dash plaque proofs back from the Laser place. You guys should like them I'll try to sneak in some third-gens the next time we do dash plaques for events.
Old Sep 25, 2002 | 12:32 PM
Guido's Avatar
Car: 2000 Trans Am
Have no idea what its going to do on the dyno. It should be interesting that's for sure.
Not using that bandclamp. That is what I had at the moment to hold it. LOL
Have some clamps to hold it.
Old Sep 25, 2002 | 01:30 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Wow. That's one heck of an engine bay.
Old Sep 25, 2002 | 02:46 PM
bhaas's Avatar
Looks sweeeeet. I hope my TT project looks at least half as good as that. Very nice.
Brad...
Old Sep 26, 2002 | 02:17 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I particularly like the upper radiator hose
Attached Thumbnails Made MAJOR progress today! Car about ready to start-belt-close-hose.jpg
Old Sep 26, 2002 | 09:09 AM
Guido's Avatar
Car: 2000 Trans Am
You should see the lower one! It is snaked around the oil drain, crossover, turboutlet and crank pulley. NOT FUN! LOL
Old Sep 26, 2002 | 09:30 AM
MdFormula350's Avatar
very nice i wish i had the money to do that to my car!!
Old Sep 27, 2002 | 01:10 AM
BlownBird's Avatar
Is that thing running yet?
Old Sep 27, 2002 | 08:40 AM
Guido's Avatar
Car: 2000 Trans Am
It turned over last night and popped a couple times! Fixed 3 leaks and then found one more. It was late so we went in. It did pop like it wanted to start though!
Going to get it running tonight for sure.
Old Oct 3, 2002 | 09:56 AM
Chris87TA350's Avatar
Well? Just kidding!
Man, that thing's amazing, Guido...
One day I wanna build a twinturbo 406 SBC Trans Am. Can't I flip over some shorty headers as turbo manifolds? This is way in the future, but I was curious. What would be a good size of turbos to run in a setup such like that? I read the post about the guy with the Vette with P52s who made 1200hp... that's kinda what I was thinking about, but with less complicated turbo manifolds as I said above...
Once again, amazing car! Can't wait to see a video or something! What are you doing to the rest of the drivetrain/suspension to beef it up? Dana 60 rear? Ford 9"? Hope you get it runnin' soon, and good luck with it!
Later,
Chris
Old Oct 3, 2002 | 10:20 AM
Guido's Avatar
Car: 2000 Trans Am
The whole car is on par to handle this setup. 9" rear end. cage. spohn torque arm.
If you want to see more, check out my webpage. ALl my mods are listed there.
www.hustonstreetracing.com
EDIT: The car is running. I hope to drive it by this Sunday.
Old Oct 6, 2002 | 01:23 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Well??? It's Sunday!
Old Oct 31, 2002 | 07:08 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
hey did you get the tube to quit blowing off? What happens if a guy puts the TB at the turbo inlet and flanges the spot where the pipe that normally feeds the TB and bolts it to the intake elbow? It might be too much for you to do now in hind sight but how about if it is designed that way from the get go. will it restrict the incoming air to the turbo too much? can a flange be welded to the TB to give a rigid mounting? I see this really thick blue silicoln hose used on turbo trucks that can withstand exaust gasses or be used on the intake tract have you seen it before (some fords have it stock)? If you got a section of that it might be "blow proof"
Old Oct 31, 2002 | 07:51 PM
Guido's Avatar
Car: 2000 Trans Am
I fixed the tubes blowing off. i figured you saw that in another thread.
I flared all the tubes.
Old Oct 31, 2002 | 09:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I saw it but I wasnt dure if it fixed the prob, Im sure that slick heim link did.
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
