130-30299 tail mount kit Q
Old Oct 6, 2002 | 08:01 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
http://www.jegs.com/cgi-bin/ncommerc...15&prmenbr=361
ok kit description says to use the 200c driveshaft
now, any knowledgable person knows that a 200 is roughly 3" shorter than a 700r4/9" tail th350
and also that the 200 c driveshaft will also be roughly 3" longer than a 700r4 driveshaft.
apparently this kit is actually designed for use with a short tail 6" tail th350
am i wrong ?
if im not wrong then im just gonna part the car out and save time and trouble and $ too. body tub is total scrap and drivers door is on borderline shape for salt belt and pass door is dented in and all interiror is trashed ripped up bad and not even original seats on top of that,. either that or ill gut the hell oput of car and use it for weekend fun street car.... weld up all holes and floor pan with pieces of door or hood skins..
thanks
Old Oct 7, 2002 | 03:01 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
important Q this is.. the answer to this Q is what the fate of this car is hinging upon.,
if the kit wont work with a 9" tail th350 then thew car is getting cut.
thanks
Old Oct 8, 2002 | 10:58 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ttt
Old Oct 9, 2002 | 09:00 PM
Nordbert's Avatar
If the 700-r4, T5 and TH350 w/9" tailhousing are the same length, your driveshaft will work. Just remove the torque arm mount from your old tranny and put it on the bracket. I have read that you need a new or different mount, but I used the one from my T5 and had no problems with it. The crossmember was
difficult to find. Having a new driveshaft made was cheap and easy
Old Oct 9, 2002 | 09:12 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeah everything on the car already should work, just need the bracket is all.
thanks guys
Old Oct 11, 2002 | 12:10 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
any other info on this subject that i should know would be great to see
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Aug 23, 2015 03:49 PM
