coil spring isolators
Old Oct 15, 2002 | 02:47 PM
AFast83z28's Avatar
where do the coil springs isolators go>? i think they carry htemin jegs or summit
Old Oct 15, 2002 | 03:14 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
they are mounted on top of the rear coil springs.
Old Oct 15, 2002 | 04:11 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
They go onto the top of the coil to reduce road noise and what not. I took mines out of my car though. One reason to lower the car allitle bit more (yes I know its only like 1/4" or less but hey its still something) and another reason was to get rid of any play in the suspension. (metal to metal sounds better then metal to soft rubber to metal)
Old Oct 15, 2002 | 06:12 PM
ebmiller88's Avatar
They go on the front springs too. Lookie here:
Old Oct 15, 2002 | 06:22 PM
right, but the ones they sell in Jeg's /Summit are the rears.
Old Oct 15, 2002 | 06:36 PM
ebmiller88's Avatar
I didn't know they had 'em.
Ed
Old Oct 15, 2002 | 07:51 PM
AFast83z28's Avatar
rear
monkey crap. so how long would it take to get some polyurethane coil spring isolators for the front in if i ordered them at a parts store?
Old Oct 16, 2002 | 01:42 PM
ebmiller88's Avatar
That's just it...your local parts store won't have them. That's not a regular replacement item. The dealer will have them in rubber, but maybe not in stock. I had to order mine and it took 2 days to get 'em.
I waited 10 weeks to get the front ones from ES and finally gave up 'cause they kept pushing the ship date back. They may have them now tho. They're cheap, less than $5 each.
Ed
Old Oct 16, 2002 | 02:47 PM
Whoa! ES has the front ones too?!? Do you have a part # for those? Thanks!
Old Oct 16, 2002 | 05:52 PM
ebmiller88's Avatar
Here's the link to the ES coil spring isolator page. It's been too long since I measured mine, but they're one of the style "A" ones.
http://www.energysuspension.com/sboots.html
Let us know if you are able to get them or not.
HTH...
Ed
Old Oct 16, 2002 | 06:09 PM
Thanks Ed!
Old Oct 17, 2002 | 10:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, Drop,
I'm interested in the correct size as well. Should you find the correct sizes/part numbers, please post.
JamesC
Old Oct 21, 2002 | 03:48 PM
ebmiller88's Avatar
Here is a pic of my old front isolator. Judging by what the tape measure shows, you would need part #9.6108 or 9.6120. The old one is about 1/4" thick.
I think. HTH
Ed
Old Oct 22, 2002 | 10:22 AM
JamesC's Avatar
I checked Summit for ES spring isolators, and while the 9.6108 number came up, the application guide doesn't list Camaros.
JamesC
Old Oct 22, 2002 | 10:55 AM
James,
I don't think that ES lists specific applications for these, as they are considered 'universal' applications. The numbers that Ed gave sound like they are about the right size, although it is hard to measure from an old isolator as these tend to distort badly (especially the rears) once they begin to wear.
Old Oct 22, 2002 | 11:07 AM
JamesC's Avatar
The application guide did provide a fairly healthy list of cars for the part number, but as I say, the Camaro was not listed. If need be, I can go stock--or order stock, measure them, and reorder.
JamesC
Old Oct 22, 2002 | 03:09 PM
ebmiller88's Avatar
If you'd like my opinion, I'd get the stock rubber pieces and be done with it. It's not like these pieces do a lot of work. Plus, they're only $5 each for the fronts.
See my post on rear isolators coming in a few minutes.
Ed
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
