STB and SFC's???
Old Oct 21, 2002 | 04:43 PM
Justang's Avatar
STB and SFC's???
are SubFrame Connectors and a Strut tower brace needed on a 89 Formula?
if so, what are the best and how much are they?
Old Oct 21, 2002 | 04:47 PM
Justang's Avatar
p.s. it has T-tops
Old Oct 21, 2002 | 08:01 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Depends on the plans for the car. Those two are prolly the single two most noticable chasis mods that can be done. Even on a stock car. Stiffen it right up.
Old Oct 21, 2002 | 08:03 PM
Justang's Avatar
daily driver. but want the suspension to be fairly stiff.
going on the car within a couple weeks:
Eibach Sportline springs
Bilstein shocks
Old Oct 21, 2002 | 09:04 PM
Z28DJP1987's Avatar
In my opinion and that of many other 3rd Gen owners, YES!
Old Oct 22, 2002 | 06:11 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i can tell you that is it almost NEEDED on most t-top cars. it is something you won't regret.
Old Oct 22, 2002 | 07:50 AM
Mike1's Avatar
I read that a wonder bar will do a better job of of bracing the front end, if I already have this would I notice anything from a strut tower brace on a dailey driver?
Old Oct 22, 2002 | 08:21 AM
Z28DJP1987's Avatar
The STB just impoves and tightens the front end over the stock Wonder Bar which helps.
Old Oct 22, 2002 | 08:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
the wonderbar and STB do diffrent things.
the "wonderbar" or steering box brace ties the lower front frame together, it is there to prevent stress cracks.
the strut tower brace, does what it says it does, it braces the strut towers, so that under hard cornering, the strut towers cannot move in realationship to each other.
Old Oct 22, 2002 | 12:34 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
you will DEFINITELY want to do these mods., especially if you are going to put stiffer springs/struts/shocks in a t-top car! you won't regret it.
Old Oct 22, 2002 | 01:09 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Originally posted by Justang
daily driver.
You'll regret that one if you do it. Go with the prokit, the sportline in my opinion is too big of a drop for a daily driver you're handling will be TOO stiff, you'll scrape on everything, speedbumps will be completely out of the question. Then bump steer issues and other things with youre suspension geometry will make it a poor choice. Save yourself the trouble and just sacrifice the 1/2'' and get the prokit. It still looks great.
Old Oct 22, 2002 | 01:55 PM
Justang's Avatar
well right now the car is lowered 2" in the front. the dork who had the car before him cut the front springs to give the car a rake. DUH!
so here goes:
Eibach Prokit
Bilstein shocks
SFC's
Old Oct 22, 2002 | 03:12 PM
Yeah, what he said! Sportlines are a little low/stiff for a daily driver... unless you always wear a kidney belt when you drive! With the other mods you will be doing, your suspension should be plenty stiff.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
james_fearn
Aftermarket Product Review
Jul 20, 2001 06:46 AM
