Does Gm still produce the 400 block?
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
If so whats the part number?
Chris
Chris
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
79 or 80 was the last year they produced a production block. You can still buy a 400 bowtie block which is a much better casting to use.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
ward,are you sure about the dates the 400 block was produced?? i have a 67 bonneville with a 400. im not tryin to be a smartass...im just curious. you can still get a 400 i believe, but i think its definetly gonna be a special order type deal. they dont put them in any of the production cars.
Justin
Justin
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Car: 87 IROC L98
If your 67 bonneville has a chev 400 block in it then someone did an engine swap. Pontiac used their own engines back then. A Pontiac 400 is not a Chev 400.
I just checked my books. 1970-1980 were the production years for the 400 SBC.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
The last 400 fitted block part# is 14008958 & has long been discontinued. You can buy 4.125" bore bare blocks through GM Perf Parts. https://www.spoperformanceparts.com/...html?CATID=628
World & Dart also sell similar blocks.
Car: 86 Trans AM
Ohhh yeah... I didnt even think about that. Its definetly the original motor. I just thought GM produced the same blocks for everything, but then the individual companies added their own goodies. Hey anyone wanna see a pic of my 400 can follow the instructions in the sig
Justin
Justin
Car: 4
Engine: 6
Transmission: 5
There were 400s from Chevy, Pontiac, Buick, and Olds over the years. Absolutely nothing interchanges, except the points and the rotor, and the spark plugs in some cases. It was lunacy. We can argue all day long about which one was the best; but having 4 of them was certainly ludicrous.
Car: 1986 Sport Coupé
Engine: 305-4v
Originally posted by Ward
Oh yeah, i completely forgot that the pontiac didnt use chevy engines until 1981.
Originally posted by RB83L69
If only!!!
If only!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
