Polished Plenium
Old Nov 13, 2002 | 12:55 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Polished Plenium
Does anyone have pics of their polished tpi plenium that is refferred to in the Tech Articles? i want to try this endeavor but it sseems like a lengthy process.
Old Nov 13, 2002 | 02:24 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Re: Polished Plenium
Dood, I know your new.
So I'll go easy on you.
There is a search feature in the boards, that will gain you access to all the info you want on polishing plenum.
Try it out.
I'll even make it easy, here's the link <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a>
Old Nov 13, 2002 | 08:41 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Here is my polished Plenum....
Old Nov 13, 2002 | 09:25 AM
87transam5.7tpi's Avatar
mine is in the sig. picture.
Old Nov 13, 2002 | 11:21 AM
Jza's Avatar
Jza
Here's mine. And, yes, it is a lengthy process. That's about 12 hours of manual labor there.
The HSR was a lot easier to polish.. hehe. Took me about 40 minutes to accomplish the same level of polish with a power sander.
Old Nov 13, 2002 | 01:46 PM
HamSpiced's Avatar
HSR???
Oh and Kj Rock.... sorry man, yea i didnt know about the search thing. sorry. lately ive just been going through each individual forum and i didnt see any topics that matched what i was wondering. sorry. and i dont care what anyone else says. your avatar rules.
Old Nov 13, 2002 | 01:56 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Not quit done yet......but will be next spring...
(1991 Z28 5.7 TPI L98)
Old Nov 13, 2002 | 01:59 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
HSR=Holley Stealth Ram.... a much better flowing form of fuel injection than TPI...
Old Nov 13, 2002 | 02:02 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
HSR???
Tha's kewl dood.
I just wanted to let you know, before some others jumped on you.
Some of these questions get asked really alot, and others not so much. The worst you could do is post it, and no one answer you, right?
Have fun with the polishing... It sure makes it look way kewler.
Old Nov 13, 2002 | 06:42 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
In the tech article on the site it says you need 3M marine aluminum restorer (found at Advanced Auto/parts america)
I searched everywhere around my house without being able to find this stuff.... Is there anything else that works good to polish the plenum??
Old Nov 13, 2002 | 06:45 PM
Kandied91z's Avatar
i don't have polished, but i will tell you that if you plan to powder coat or chrome plate anything polishing makes all the difference. most of this is ceramic coated; soon to be polished and chrome plated if i can't sell the pieces.
Old Nov 13, 2002 | 07:29 PM
HamSpiced's Avatar
Kandied.......about your car... did it have the dual intake thing, and you just put a cold air induction on it or what. im really curious cause that looks really cool.
Old Nov 13, 2002 | 07:31 PM
Kandied91z's Avatar
had the stock intake setup, i used a cover that is commonly found on the carbed models and custom fabed up a CAI (cold air induction)
thanks for the compliment!
aren't you in michigan, could have one built for you. i'm selling mine although i doubt you want to spend 200 bucks on an CAI even though it does work extremely well and makes the car sound like it's supercharged when it's running.
Old Nov 13, 2002 | 07:52 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
Here is mine:
Old Nov 13, 2002 | 11:28 PM
HamSpiced's Avatar
i seriously wanna cry when i see these beautiful cars. a few things... i as well cant find this alum polish. any ideas where else to look. those runners are beautiful how much do they run like 300? and yea i live right in detroit.
SBrice...... wheres your MAF???? that look ssweet!
Old Nov 14, 2002 | 02:32 AM
Kandied91z's Avatar
i'm looking for stock pieces that i can repolish and chrome plate instead of my ceramic coating....... if your interested in anything under my hood let me know. i've got about 800 into the coating; but i'd take around 1/4 of that if you had identical stock looking pieces to swap.
just a thought....
sbrice18fan; sharp looking bay, the headers are the only thing setting you back from being spectacular! looks good.
Old Nov 14, 2002 | 07:08 AM
Thanks, Yeah I am not sure what to do to the headers, I can't really afford to buy another set of SLP's.
Old Nov 14, 2002 | 11:30 PM
nblanchard's Avatar
I'll tell you how I did mine...
Runners
- Hand sand them with wet sandpaper working from 180 grit up to 600 grit.
- I had access to a dual heavy duty buffer, mainly used for stainless, and this worked wonders. The compound were those brick type, where you put it on the buffing wheel, not the part.
- Did some final detail buffing with a rag and metal polish (autosol, mothers.. etc etc)
Plenum
- Took down the cast roughness with a D/A sander and 140 grit pads.
- Hand sanded with 180 wet up to 600.
- And buffed them like the runners
There was some tricky spots that I used a die grinder and dremel, with a buffing bit, to get at them.
And, here is the final product...
Old Nov 14, 2002 | 11:36 PM
HamSpiced's Avatar
looks beautiful. so you can polish the runners too i assume? what exactly do you use to polish the aluminum you etc on that. ill buy the stuff tomorrow.
Old Nov 14, 2002 | 11:39 PM
nblanchard's Avatar
I had stuff I got from a car show... I forget what it is called... I've used the Mothers Aluminum Polish, and it works very good. I had the advantage of having access to the heavy duty buffing machine... it took out a lot of the sanding marks. So I recommend going up to a higher grit, like 1000.. this way you can polish them by hand after.
Old Nov 15, 2002 | 12:12 AM
Kandied91z's Avatar
looks good, now you should do the condenser and the lines to match.......a few small but key peices and that bay would look sweet!
Old Nov 15, 2002 | 12:16 AM
nblanchard's Avatar
I was planning on doing a lot of stuff during the winter.. but my winter storage is no more
Old Nov 15, 2002 | 04:33 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
How many hours of work did it take to get the plenum and runners looking that good???
Old Nov 15, 2002 | 04:39 PM
nblanchard's Avatar
Took me round 10 - 12 hours total
Old Nov 15, 2002 | 04:53 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
thats not that bad...i'm gonna have to get around to doing that next spring...it really improves the look of the TPI....
Old Nov 15, 2002 | 05:06 PM
nblanchard's Avatar
yes.. and believe it or not, it is easier to clean because there's no roughness to them anymore
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
