Installing hood pins
Old Dec 1, 2002 | 11:45 PM
Rage13's Avatar
Car: 89 Firebird
On my way to Moroso last weekend I noticed my hood shaking and lifting a little bit.. (i'm sure it was from the 120+ mph i was doing to cut down the time ) to get to the point, i want to put some hood pins on, how did you guys mark where the holes should be? i'm planing on puting the pins in and puting a little paint on the tips to mark the under side of the hood to drill. any one have some other or better way they know of?
Old Dec 2, 2002 | 03:59 AM
88CRUZIN's Avatar
hey-dude-a-friend-of-mine-took-off
those-2-rubber-bouncers-that-are-on
the-corners-towards-the-front-of
the-hood-then-he-just-put-the-pin
through-there-and-drilled-a-hole
through-the-hood.the-pins-will-be
perfectly-lined-cuz-those-holes
are-made-allready.dont-know-if-this
helps
laterz
88cruzin
Old Dec 2, 2002 | 08:16 AM
Dewey316's Avatar
Car: 1990 Camaro RS
please-use-the-space-bar.
Old Dec 2, 2002 | 08:27 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I believe his space bar is broken.
Old Dec 2, 2002 | 03:18 PM
Rage13's Avatar
Car: 89 Firebird
i've got some holes next to the rubber things, not sure what they were really for but they are in the perfect locations i was really just woundering if there where any other known ways to mark where to drill the holes in the hood.. seems like its been a pretty long time sence you broke your keyboard, isn't it time for a new one? it's only like $10..
Old Dec 2, 2002 | 03:37 PM
Boosted GTA's Avatar
This is the easiest way to make sure the holes line up.
Place your hood pins in the engine bay, where you would like them placed. Take some double sided tape to temporarily hold em in place after you measure to be sure where they will be placed.
When you have the pins secured to the location you want, take some lipstick (i know, i know...just borrow your girlfriends!) or some axle grease and put a big glob of it on the top of the pins.
GENTLY lower your hood and make sure it makes contact with the pins. When you raise the hood, the big glob will be transferred onto your hood. Then drill her out!
I always drill a small hole first, then lower the hood to make sure the alignment is dead on...then drill to the proper size. Use a higher speed drill with moderate pressure to avoid mis-shaping the area.
Hope that helps.
Mike C.
Old Dec 2, 2002 | 05:12 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i used the method you are talking about. instead of paint, i used grease. then drilled a very small hole. the i increase the size of the hole with bigger drill bits. once i got the desired size hole i lowered the hood to check the fit. from there i had to do a little bit if filing and the everything looked good.
Old Dec 2, 2002 | 05:56 PM
Rage13's Avatar
Car: 89 Firebird
cool, thanks guys!
Old Dec 2, 2002 | 08:40 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
pics????
Old Dec 3, 2002 | 12:21 AM
88CRUZIN's Avatar
hey-guys-but-thats-10-bucks
of-gas-i-can-burn-up!
88cruzin
Old Dec 3, 2002 | 07:21 AM
scauffiel's Avatar
http://www.transamtemple.com/modific.../hood_pins.htm
S.
Old Dec 3, 2002 | 05:17 PM
Car: 84 camaro Z28
Engine: 434sbc
heres a pic of my pins
Old Dec 3, 2002 | 07:05 PM
Ringmaster72's Avatar
Car: 1989 IROC
If you look closely you can see my pins.
Tim
Old Dec 3, 2002 | 08:58 PM
Rage13's Avatar
Car: 89 Firebird
sweet guys, thanks for the pics and all the help i'm going to pick up the pins and put them on this weekend, then i can test'em out on my way to Moroso on the 22nd any one in south florida going there for the Outlaw races?
Old Dec 4, 2002 | 06:15 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I'm gonna try to get up there, work permitting
Old Dec 4, 2002 | 03:11 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Anyone have a problem with rusting? I was told that the hole might rust where you drilled it. Any ideas?
Old Dec 4, 2002 | 03:44 PM
Rage13's Avatar
Car: 89 Firebird
in florida rust is always a problem, i can just imagine the rust flowing the drill as it gose into my hood... as for stoping it i plan on painting it with some rust stoper stuff at work, hope it holds up to its name
hey dans82bird if your going give me a pm? maybe we can ride up there togeather
Old Dec 8, 2002 | 11:00 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Go to the yahoo link in my sig and you can see where I place my pins with the hood up,m as well as some other shots of the pins, I believe.
Later,
Jesse
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
