Who can show me where to drill a hole in my 'stat? Pics??
Old Dec 2, 2002 | 01:05 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I dont use any thermostat at all, and the motor goes up to 180 before I turn my fan on. I want some restriction in there, it takes forever to warm up, as you could imagine, so I'm gonna put my 160* 'stat back in, but I want to drill it. Where do I drill the hole(s), how many, how big? If someone has a picture of theirs that would be great. Thanks
I've got an aluminum pump, 3 core radiator, flex fan, and 10" electric fan. I never put my A/C back on since I did the cam.
Old Dec 3, 2002 | 03:21 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Here ya go: 3 holes, about 1/8 inch.
(it's a Robertshaw 'stat)
Attached Thumbnails Who can show me where to drill a hole in my 'stat? Pics??-stat.jpg
Old Dec 3, 2002 | 03:25 PM
thanks for the pic Speedcat, but I'm using a regular type thermostat made by Stant, it doesnt look like yours. But the idea is the same. Compared to where you drilled the hole in yours, where should I drill a regular one?
Old Dec 3, 2002 | 09:42 PM
SpeedCat86's Avatar
Most of the standard-type 'stats i've seen are drilled on the rim, about where I put the red dots on this picture. Again, about 1/8" holes.
Attached Thumbnails Who can show me where to drill a hole in my 'stat? Pics??-bstat.jpg
Old Dec 3, 2002 | 09:45 PM
thanks man
Old Dec 5, 2002 | 10:44 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Last edited by MikeInAZ; Aug 20, 2006 at 10:56 AM. Reason: convert html to bb code
Old Dec 8, 2002 | 02:56 PM
MdFormula350's Avatar
the drilling holes in the t-stat seems to be popular.
Old Dec 8, 2002 | 03:35 PM
DABE's Avatar
whats the "gain" of drilling it out??
Old Dec 8, 2002 | 09:04 PM
IHI's Avatar
IHI
Most people running electric water pumps drill 3-4 1/8" holes in the stat so it'll relieve some of the strain on the electric pump, how much this helps in that situation I don't know, but the theory sounds good. I just did it when I rebuilt my motor cause everybody was saying to do it, gains-???
Old Dec 9, 2002 | 07:03 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Prevents "hot pockets" from building in your engine block and will help eliminate air from the cooling system.
Old Dec 18, 2002 | 01:10 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
yes it doesi had a small problem with my car overheating i had replaced everything and not even griffin or be-cool could figure it out. any how long story short. i drilled one hole in the stat, and it fixed the air pocket problem because normal ways wouldnt get rid of them.
Old Dec 18, 2002 | 09:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i have a 160 stat that i drilled two 1/4" holes in it. warms up quick in the summer, i dont run this stat in the winter.
i like drilling holes
Old Dec 24, 2002 | 01:56 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
i guess drilling holes is pretty popular in the stat, i did it in mine because in the summer, my car would heat up too quick and then overheat(remember its like 120*) i drilled 3 1/8" holes around the side to just let some flow in before the stat opened, seemed to work for me, never go above 200* anymore...
Old Dec 28, 2002 | 01:03 AM
Originally posted by fast86z28
....never go above 200* anymore...
200??? Man, I start to panic when I hit 185! I like mine to run at about 170 all time. I'd like to get it to run about 130-140 all the time because that's when it runs the best but we all know that can't be accomplished in the summer time.
Old Jan 1, 2003 | 07:44 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I second that.
Kat
Old Jan 2, 2003 | 09:58 AM
that temp (130-140) should not be where you are getting optimum performance, or the aftermarket would produce 135* stats. sounds like you need some tuning if you want optimum performance (which needs to be at a higher tmep)
Old Jan 16, 2003 | 04:17 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Our cars are built to run between 195 and 220 all day long and not have problems. I used to freak out too when it hit 200....but not anymore. Just remember you're getting your best mpg at about 195-200.
Old Jan 21, 2003 | 02:10 PM
Jworking's Avatar
Drilling holes will keep the water on each side of the thermostat the same temp and keep it from opening and slaming back shut again. This save wear and tear on the radiator. Many makes, Olds, Ford and others (LS1 GM) and others have t-stat bypass systems. I do lots of cooling system work and I recomend it... highly..
Old Jan 21, 2003 | 08:01 PM
burnoutrpm's Avatar
"Our cars are built to run..."
That line is the biggest load of BS I've heard ... and I've heard it multiple times. You see, GM built our cars to run 195-200 all day long. That's STOCK! I no longer have a stock car. MY car is built differently than what GM originally built and therefore you cannot use the line "Our cars are built to run...". That's like saying "Our cars were built to run on 91 octane gas". Maybe from the factory but you try telling that to somebody that's not running the same compression as they were stock. It's all about how you build it.
And for the skeptics out there ... take your car to a real dyno and see if it makes more power at 120 degrees or 220 degrees. I think you'll be suprised.
Let's not forget... viscosity and HEAT break down oil, the protector of your rings and bearings. Keep running your engine at 200 degrees and I'll stick with my cooler, better protected engine.
Old Jan 21, 2003 | 09:41 PM
llvll4l2c91350's Avatar
I agree. Heat is the enemy of engines and transmissions. The only reason why our cars were designed with a high temp stat was to cut down on emissons. When I used to open the hood after a drive on my previous Formula it felt like an oven cuz it had the stock stat. With the 160 stat I have on now I can leave my hand on the upper radiator hose without getting burned. Plus I have a manual fan switch installed. It's pretty safe to say that an engine constantly running at 200* will wear out faster than an engine running at lower temps.
Old Jan 23, 2003 | 09:09 PM
patrickm00's Avatar
since i swapped my 195° for a 180°, i no longer have the near-overheat problems when i idle in traffic in the summer with the a/c on (which btw makes the a/c perform like crap). my gas mileage hasn't changed any, except maybe 1/2 mpg worse in the winter than normal (~16-17 around town, last winter was like 17-18 ish, though i have a new engine still with 10W40 in it for another month). one other thing i noticed- not only does it keep the engine a bit cooler, which prob protects it a bit better, it also keeps the alternator 15° cooler, which not only improves its efficiency, but also its lifespan. heat is the enemy of any part with lots of inherent resistance or friction, especially if it's electrical.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
BADNBLK
Nov 16, 2016 09:12 AM
aaron7
Aug 17, 2016 06:02 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
