Southern California Area Southern California Members.
Updated roll bar pics...
Old Dec 4, 2002 | 04:47 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Here it is, as it sits today. Yesterday I welded in the side bars. I need to paint them to match the exterior (headed for the paint store now) then the interior can go back in.....
Old Dec 4, 2002 | 04:48 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Dec 4, 2002 | 04:49 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Dec 4, 2002 | 04:51 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I am going to order new carpet too... Any suggestions on where to get it from? I want it to look factory new again, mine is a little off-color of what it was when I bought it.
Old Dec 4, 2002 | 04:52 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Dec 4, 2002 | 04:53 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Dec 4, 2002 | 09:02 PM
Jason92Z's Avatar
Car: 08 Nissan Altima
Engine: Stock
Transmission: Stock
Jason, In these pics i can see a little better the color of your car. If you look at the reflection of the sky, and it has that teal look? Mine does the same thing, so im willing to bet that its going to match just fine.. Cant wait!
Old Dec 4, 2002 | 09:36 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
are the arm rests going to fit? that seems to be an issue w/ some cages/rollbars.
Old Dec 4, 2002 | 09:43 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
No, the armrests are no longer. I bought the arm rest compatible door bars, but with my shoulders being so wide, it would have been against my arm at all times, so I just used straight bars. I have no desire to deal with that, so the armrests had to go. I plan to make some custom door panels with some type of handle to pull the door closed, no need for a rest now, the bar can serve that purpose. Getting in and out is actually very easy, the bar can be used to push yourself up when exiting, and sliding in is a piece of cake. My wife actually was impressed That alone says something....
Old Dec 4, 2002 | 10:05 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
how much was that/ whered u get it at i was thinkin about putting a roll cage in my car after a few little things that i need to take care of
Old Dec 4, 2002 | 10:09 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I have had it for a few years, I just finally got around to finishing it. I don't remember the cost, but it came from S&W Racecars directly, check thier website for pricing.
Old Dec 4, 2002 | 11:53 PM
Jason92Z's Avatar
Engine: Stock
Transmission: Stock
I looked up the difference in colors for the 1991 and 1992 camaros, and it looks like in 1991 there was Ultra-Blue and Meduim Maui Blue. In 1992 there was only Medium Quasar. I dont know what to expect now...I guess it comes down to what age did to the paints..
Old Dec 5, 2002 | 09:18 AM
chevy2ss's Avatar
Car: 63 Nova SS, 91 Camaro Rs
Have any pics of how the bars in the hatch section are attached ?
Old Dec 5, 2002 | 10:51 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Looks real good Jason!
Have you considered making a hatch for the fuel pump replacement? I think if it's finished very nice it would be super cool. I plan on doing mine.
Did you arc weld that together?
Old Dec 6, 2002 | 05:12 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I actually do plan to put a "door" above the tank sender. As for welding, I used a Miller wire feed..
Old Jan 15, 2003 | 10:49 PM
jester111's Avatar
RU-QWIK nice car
I was on the boards today and I replied/asked question when I ran across this post. Did you install the cage yourself if so how did you level the car so you know for sure it was not in a bind? Like I said in the other post I had read a few articles in hot rod and carcraft and each article contradicts the other. The car should be on its wheels and suspension loaded , the other states the opposite that the car should be on jack stands away from the suspension point. I would like your advice as well as anyone elses on this matter. I plan on installing my cage asap.
That question I should also ask for installing subframe connectors.
Thanks inadvance!
P.S. California must be nice!!! Ill I see out my window is snow snow snow
Old Jan 15, 2003 | 11:15 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Re: RU-QWIK nice car
We have started another warming trend. Thursday is supposed to be 79 degrees where I am and Friday around the same. Maybe I can hit the beach Saturday if the weather keeps up
Old Jan 15, 2003 | 11:30 PM
leo037's Avatar
Car: 92 RS with B4C Package
Axle/Gears: 323
sweet. did you do all the welding? nice job
Old Jan 15, 2003 | 11:38 PM
jester111's Avatar
trans87
talk about rubbing it in
Im in Toronto, and let me tell you its f*^k#$g freezing out side!
I was in LA for the first time in late Aug early Sept it beautifull
im extreamly geolous. Except for the nite life clubing wasnt what I expected. Atleast you guy can drive year round.
Old Jan 16, 2003 | 11:40 PM
trans87's Avatar
trans87
LMAO You know what the worst part is? When it is cloudy or when it rains people actually complain about it. I mean it's sunny for like 11 months straight and when a couple days of bad weather comes in people are up in arms I wouldn't mind seeing a little cooler weather, today was warm! Damn 80 degrees the news said. A little too warm for January. If it keeps up like this we will have a major drought situation.
Old Jan 17, 2003 | 11:26 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
leo.. yes, I did all the welding.
Speaking of weather, it is a little on the cold side this morning here in central California. I came home from work to find a little ice around the house...
Old Jan 17, 2003 | 11:27 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
rear of the cold camaro...
Old Jan 17, 2003 | 04:15 PM
jester111's Avatar
ru-quik ahh thats just alittle frost
so you never answered the question, how did you or did you level the car before the installation?was it on its wheels?
trans87 80degs thats our summer
Old Jan 17, 2003 | 06:58 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I had the car in my garage, the front and rear were on jacks, as if it were on the ground though. I had the garage checked for being level by a friend that does surveying for a living. I now have a rack at work made specifically for doing sub frame connecters and rollcages, that should make matters much easier.
Old Jan 17, 2003 | 08:44 PM
Russ-So Cal's Avatar
You have a rack at work? I thought the company you worked for made pistol grips. Did they put in a shop for employee car nuts? Awesome company!
Old Jan 17, 2003 | 10:39 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Actually Russ, I have two jobs... Yes , one is a major business in the gun industry, but the second is at a local motorsports shop. We have only been open for 8 months now, but the work load is outrageous. The main work is installing lift kits, but there have been a number of Camaros and Mustangs getting subframe connectors, exhaust, superchargers, nitrous, etc. This job is by far the funnest work I have ever done, doing what I enjoy, and getting paid for it...
Old Jan 18, 2003 | 04:19 AM
Jason92Z's Avatar
Engine: Stock
Transmission: Stock
Jason, are we still going to try and swap hoods? or blisters or whatever.. let me know.. also, has your car been repainted? and if not, what month was your RS produced?
Old Jan 18, 2003 | 10:55 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Yeah Jason, I would still like to trade the hoods, but I have been so busy lately with work, I have not had a chance to even think about taking a road trip.
My blue car was repainted (factory color repaint) back in 1992 under the paint recall. The hood and roof area started peeling when the car was not even a year old. Anyways, I doubt it matters since it has been re sprayed, but the car was built in November of 91.... Seems it would be a 92 model, but it is still a 91. Do you have the paint code from your car? That would tell us if it is the same blue or not.
Old Jan 18, 2003 | 03:34 PM
Jason92Z's Avatar
Engine: Stock
Transmission: Stock
The VIN number would tell me that... My car is a 3/92 production date... I have worked with many new car dealerships and anything after Sept is basically the next year model... You MAY be the same exact color as me... I will look up my vin and get you the color code... Thanks Jason... I would be more than willing to meet you half way...
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
