Anyone Familiar w/ this engine?
Old Dec 6, 2002 | 02:26 AM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
im going to buy a new engine for my v6 and i was looking at this engine... its in my price range. but it dosent say how much HP it has or anything... what do you guys think?? can you tell me any stats on it? its a replacement for a caprice or a fleetwood
http://www.sdpc2000.com/cart.asp?act...id=128&pid=105
i also was looking at this one but it seems to be a bit overpriced to me... but i dunno
http://www.sdpc2000.com/cart.asp?act...id=128&pid=110
any help is appreciated, thanks
EDIT: my car is an 87 v6 bird standard... and i have an 89 Trans Am TBI Auto doner car, ill be able to use a bunch of stuff off the trans am right? i was going to originally use that engine but its still pretty slow
Old Dec 6, 2002 | 11:29 AM
jharms's Avatar
Two things, first off the caprice 350 probably makes around 230-240 HP, but really you should just call/e-mail them to find out for sure.
My second thing is the second motor, which you claim seems to be "a bit overpriced" is the exact same price as the other motor, it's actually cheaper than the first motor until you figure in the $100 core charge... Plus that motor tells you exactly how much HP it makes. However it might not work with your car because it's got a 2 piece rear seal, or flex plate, or some part like that. (I've seen that mentioned before in the forums.)
What's wrong with rebuilding the motor from the '89 Trans Am? (assuming it's a 350)
Old Dec 6, 2002 | 05:23 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
its a 305 in the TA... thanks for the info... ill check out the rear seal/flex plate thing
Old Dec 6, 2002 | 06:30 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
no matter what the rear main seal is it will work, and just take the flexplate off your 305 and put it on the 350, thats what i did when i put in my 355, works just fine, no problems
Old Dec 6, 2002 | 06:58 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
thanks, what else would you reccomend i use from the Trans Am?
i know im going to have to buy a new clutch, since the TA is auto
Old Dec 7, 2002 | 03:31 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If Im reading this right, you want to go from a 2.8 with a 5 speed to a V8 with the original 5 speed from the V6 car, right?
If you are planning on using the 2.8 5 speed, it wont bolt up to a V8 pattern.
You will need a V8 5 speed bellhousing.
If I read this wrong, sorry.
Old Dec 8, 2002 | 02:38 AM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
yea i know it wont bolt up... im buying a new one for the V8, thanks for the reply thou
Old Dec 8, 2002 | 11:24 AM
flyway190's Avatar
Here are some specs, and it makes about 200hp and 300lb.-ft. or so. For more info, do a search on LO5 and 12513151 on this board.
Old Dec 8, 2002 | 01:57 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
I have the second engine in my 82 Firebird. It bolted up to the orginal transmission with no problems. It has TPI, SLP exhaust, K&N, and MSD prerformace add-ons. Other then maintenance(tune-ups, oil changes etc) I have only had to replace the EGR valve in 5 years. The TPI intake, ECU, wiring harness, sensors was purchased as a kit from Fual Injection Specielists out of TX.
I currently have 55,000 miles on the engine and its very strong.
I currently can't drive the car because a person driving a mini-van ran a stop sign and smash into the front right wheel area of my 82 Bird. All of the parts has been ordered for the rebuild and the car should go into the shop towards the end of this week.
Unfortunely since the car is 21 years old I am going to have a hard fight on my hands to get a decent settlement out of the other persons insurance.
I have told by my insurance company that once the car is fixed that I can declare a fix value on the car to protect myself. While the car is on the frame machine I am having SFCs install and the suspension will be totally overhalled. I am also putting on new 16 inch AT wheels and 245/50VR-16 BFGoodrich Comp T/A VR4 tires. Including the wheel and tires, the estmated cost of the repair is running somewhere around 10grand (just about what I paid new).
I could easily go out and buy any car out there that I want. But I like my Firebird. It has plenty of space for my 6ft 2inch frame, and is a joy to drive everday. It also does not have any of junk that current cars come with. It is a great performace machine. The combination of space, handling, ride quality, styling and performance can not be touched.
Old Dec 10, 2002 | 10:54 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Well, that first motor was used by a user name, RickTPI. Look him up. He swapped the heads i believe and is now running the Holley StealthRam. Also a different cam too i think. He has a web site with all of the info. He is running very low 13s. Whats wrong with the auto out of the V8? I would use that instead of the t5. Its stronger and with the power of the motor you can run it all day. At least get the t5 looked at before slapping it in there. Don't forget about suspension work to from doing a V6 to V8 swap. Do a search on those type of swaps, you'll find exactly what you will need.
Old Dec 10, 2002 | 10:39 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
thanks so much. the suspension.... i can use off the Trans am too cant I?
Ps: I love standard cars i dont want an auto... thats why i dont want to use it off the TA.
Old Dec 10, 2002 | 10:48 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Sure, i don't see why not. It should all switch over. good luck
Old Dec 15, 2002 | 12:56 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
i remember pace performance was selling a 350 tbi engine for ~ $1500 or so. they stated that you could pull the factory cam, drop in an LT4 cam, and make around 300 horse. but i've forgotten the part number, and pace doesn't list it on their site.
another thing too, try checking right from gm if you have the part number for the engine. go to www.gmpartsdirect.com
i was pricing a new set of zq8 wheels from pace. they wanted $599 for a set of four. and i don't recall if that included shipping or not. and it also doesn't include the sales tax.
i priced the same rims from gmpartsdirect, and could have them shipped to a local business for $525.
Old Dec 16, 2002 | 11:04 AM
flyway190's Avatar
Check the link in my post, that's the engine we're talking about.
Old Dec 19, 2002 | 06:27 PM
jimjohn's Avatar
Caprice crate motor
I replaced my tired 305 with the 12513151.
I bought mine for $1500 before the price increase last March.
I also went to the 350 injectors and stuck in a Crane 2020 cam.
Am very happy with this combination and run consistant 14.40-14.50 times with 2.07 60 ft.. With good track conditions i can get 2.02 60 ft.
This engine has an extra threaded hole in the pan which was used for a low oil indicator on some Roadmasters. I think the plug thread size is 20x1.5.
If any questions, just shoot me an e-mail.
jimjohn
Jake_92RS
Jan 28, 2020 10:37 PM
no green
Mar 3, 2016 05:19 PM
buckeyecelt
Sep 24, 2015 05:50 AM
GarageToys
Sep 9, 2002 01:43 PM
sguy30
Oct 19, 2000 02:51 PM
