RPM Questions
Old Dec 18, 2002 | 10:11 PM
jsusoutherners's Avatar
RPM Questions
1. Why does the car vibrate really hard at just under 1000RPM
(or just above idle)
2. Why do the headlights go dim while idling
Old Dec 18, 2002 | 11:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
2. You're alternator may not be charging the battery correctly.
Old Dec 19, 2002 | 11:38 AM
Vader's Avatar
JSU,
I'm guesing that this is regarding your newly acquired '86, right?
If so, I wouldn't be too concerned about the idle and vibrations until you get a fresh load of fuel into it. Old, stale fuel and carburetors (or injectors, for that matter) don't get along. You should also solve teh smoke/steam issue. But before you do that, scan the ECM for error codes and find out what those problems are. That may solve several of your issues.
Old Dec 19, 2002 | 10:15 PM
THE gas is new i just got it and when i got the car it had no gas in it....
Old Dec 20, 2002 | 02:49 PM
another question... when i let it idle for 15 or so seconds and then i give it quite a bit of gas it revs... stops reving at 15 for a split second and then revs again.... any solutions?
Old Dec 20, 2002 | 09:00 PM
Vader's Avatar
I'm guessing your new battery solved the dim lighta at idle issue, correct?
The rest is a manifestation of your fuel delivery problem, covered in your other post.
Old Dec 20, 2002 | 09:35 PM
no the new battery is the only battery i have tried...
i am sorry about that last post what i meant to say was that
if i let it idle for about fifteen seconds and then give it alot of gas it will rev up untill 1500rpm... then stop.... then rev on up.. is this normal
Old Dec 21, 2002 | 04:32 AM
Hrock's Avatar
Alt and Fuel delivery
Your alternator opeartes only above 650 rpm if it has not got Underdrive pulleys on it.. so your idle borders this in most cars.. Dont worry its normal... Your Fuel injection system ( Im guessing you have TBI/TPI ) will hunt for an idle Correction if the Idle Air control Valve is sticky.. or if something else is out calibration ( minimum IDle set screw, Tps sensor too Low, Idle too low ) The Idle Air Control Valve Steps upward to allow your air intake more air then your butterfly so that when you press the accelerator peddle down under load and lift off you dont stall the engine suddenly.. Carberators have a Idle assist valve for High-Idle and Stalling purposes aswell... You seem to have nothing to really be concerned about.. They are all easy to Tune up...
Old Dec 21, 2002 | 09:35 AM
Vader's Avatar
Hrock,
Excellent breakdown. If it helps, he acknowledged in a previous thread that the car is equipped with a carburetor (LG4 engine). We've been trying to get the initial start of the engine after its having been adandoned for an undetermined amount of time. The car has several issues, but it appears that to this point the battery is new and the engine will now run for short intervals with some throttle feathering.
With all the seemingly unrealted threads on this set of problems, it may be time to clean it all up and summarize it into one post, so the issues are easier to track and potentially related problems can be put into perspective. Analysis will certainly be more complete that way, or we can at least separate the issues into the appropriate, relevant systems.
Old Dec 21, 2002 | 10:21 AM
Vader's Avatar
Please check this summarized thread for information and replies: https://www.thirdgen.org/techbb2/sho...hreadid=150440
beastin91rs
Oct 9, 2015 07:38 AM
forstral
Aug 19, 2015 03:20 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
