View Poll Results: What thermostat are you running?
160
28
35.00%
170
11.25%
180
32
40.00%
190+
13.75%
Voters: 80. You may not vote on this poll
What Thermostat Are you Running?
Old Dec 20, 2002 | 04:32 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
This seems to be a somewhat popular point of argument amongst 3rd gen people.. I was originally running a 195, then went to 160 w/out heat, and now i'm up to a 180 w/ heat. I think i'll be content, but i'm interested to see what everyone else is running.
Old Dec 20, 2002 | 04:51 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Oh no, not this topic ... AGAIN!
Last time this topic hit the board there was a TON of arguements.
I'm not commenting any further on this topic....
Old Dec 20, 2002 | 08:56 PM
Vader's Avatar
180°F with a stock ECM and no problems for four years.
Old Dec 21, 2002 | 07:41 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Ah yes my friend from the city of Waynesstock but there is only one correct answer, a 195.
Old Dec 21, 2002 | 08:06 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
180* in winter , 160* in summer, non computer controlled too.
Old Dec 21, 2002 | 10:13 AM
1986redbird's Avatar
I'm running a 160* and have no problems at all, I still have the stock fan switch so around town it will still get to about 190* or so, but on the interstate it stays at 160* without the fan ever comming on. I don't know where you guys live that blowing air across a 160* heater core won't heat it up but " D A M N". ya'll must live in the arctic or something.
Old Dec 21, 2002 | 02:31 PM
breathment's Avatar
hehe.. it looks like no one wants to touch this topic. i dont' blame them, it has been beat to death so take a look around the previous post on this forum..
Old Dec 21, 2002 | 06:02 PM
MdFormula350's Avatar
stock 195
Old Dec 21, 2002 | 06:13 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
AC Delco 170º t-stat.
Old Dec 22, 2002 | 10:58 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
195* winter use, heat at vents is 150* with 195*. 180* Summer use heat at vent in winter with 180* are 120* as tested two weeks ago.
Old Dec 22, 2002 | 07:48 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
160 year round
Old Jan 2, 2003 | 12:58 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Ditto. This is the temp TPIS says that this is the optimal temp for Tuned Port engines.
Old Jan 3, 2003 | 07:18 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
me too...
Old Jan 3, 2003 | 07:25 PM
rezinn's Avatar
180 year round.
Old Jan 4, 2003 | 01:53 PM
TPIS :sillylol:
Those are a bunch of overpaid idiots that have too much time on their hands and make up a bunch of BS theories and charge outrageous prices.
The truth is that every car is different. You have to do your OWN testing to find out what is optimal for YOUR car.
170* "might" be optimal for a STOCK engine but I'm sure the majority of the people on this website aren't running STOCK engines.
Sorry for the ranting but I just really don't like TPIS.
Old Jan 6, 2003 | 10:24 PM
TransAmTBI's Avatar
Transmission: th700R4
thermostat
After numorous overheating problems, I had my 160 installed and finally got an air dam!!!( unbelievable difference.thank *** for air dam) BUt during these cold winter dayd it seem to run at 150 in the highway so because of my history i'm happy as hell but some may say too cold but i have to go with 160 year round and a manual fan switch!!
Old Jan 10, 2003 | 01:54 PM
kevinc's Avatar
Car: 1982 Z28
With aluminum heads, I like the hotter 180deg stat to keep the chamber temps up. The car physically felt lazier w/ a 160deg stat and I lost .3sec in the 1/4 mile consistently. Might be even better w/ a 195deg stat, haven't tested it yet.
With iron heads I'd lean toward the 160deg stat but still test against a 180deg before making a decision. Iron retains chamber heat more effectively than aluminum.
Old Jan 10, 2003 | 03:21 PM
TransAm's Avatar
An update
When i originally started this thread, i was running a 160* with no heat. I've since then replaced the heater core and the thermostat with a 180* as it said in the post above.
Interestingly enough, the temperature is unchanged. The heater core is keeping it right down around 165 or so. I also changed the antifreeze, suppose that helped.
Old Jan 12, 2003 | 12:07 AM
patrickm00's Avatar
i've had a 180* in there for a while without any problems. mostly stock engine.
also, i recently swapped my 92 conv back to the 85-90 ground effects, and since it was winter and i have no garage, i could only paint small panels and went with the red/gold look until i can get a real paint job. but i saw yours that looked to be maroon/gold, checked out the pictures you posted, and saw you were in FL and had a crappy interior. if you want a place to take it for interior work, hit "Willison Gator Upholstery" in Williston, about 25 min south of Gainesville.
the guy does real good work, and very cheap. he did all 4 of my seats in a synthetic leather for $450, and same price for cloth i think. (btw, moving back up north, the synthetic feels real good when it's warm, but when it gets real cold it feels to vinyl-like, but still no regrets for that price)
Old Jan 12, 2003 | 12:57 AM
radiateu2's Avatar
thermostat
180 with a 204 fan switch non cumputer controled of course.
Old Jan 12, 2003 | 01:36 AM
AFreaknGoodTme's Avatar
The only way to properly tell is to hook your car to a diacom scanner or a laptop and make sure it doesn't run in open loop. Mine will run year round here in So. Calif. with a 180* in closed loop.
Old Jan 12, 2003 | 02:04 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
180 all the time or a 170 drilled for constant flow. heat in the winter and still stays cool in the staging lanes at the local drags during the summer. runs a little warm during the traffic in the summer with the ac on. in my opinion the best all around.
Old Jan 12, 2003 | 06:37 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Normally they will go to closed loop after the temp hits around 105-110 degrees and the O2 sensor 550-600 deg. You can also ground the ALDL test point with the engine running and the SES light frequency and pulse duration will tell you whether its in open or closed loop as well as whether its running rich or lean.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
