removed AC, heater box question
Old Dec 31, 2002 | 12:54 AM
Camarokid01's Avatar
ok I read a post on here about a non AC heater box thing, what is it? I am quessing it deletes the big plastic box on the passenger side firewall, does anyone have pictures that they could post of this? how does it work does it cover up that big hole that is in the firwall? and last question is how do I take off that big plastic box on the firewall?
Thanks in advance
Old Dec 31, 2002 | 02:59 AM
MdFormula350's Avatar
heres a pic of the standard heater box..
Attached Thumbnails removed AC, heater box question-standardheaterbox-202-3-2002.jpg
Old Dec 31, 2002 | 11:11 AM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
After seeing the pic I'm sure most of your questions are answered. As far as taking out the a/c box goes take out the bolts that hold it in 3 outside and one stud outside and 3 bolts inside the car hold it on, Take those out and the pull it out, it's pretty easy. I just finished mine up so if you have any questions just let me know.
Old Dec 31, 2002 | 12:30 PM
so that heater box just covers up the big hole the AC one leaves? and after the bolts outside of the car and the ones inside the hole thing just pulls out? Is there a box type thing behind the dash to? do I have to take the whole dash apart?
Sorry for all the questions, thanks in advance
Old Dec 31, 2002 | 02:27 PM
Car: 88 IROC
Transmission: pg
Originally posted by Camarokid01
so that heater box just covers up the big hole the AC one leaves? Yes
and after the bolts outside of the car and the ones inside the hole thing just pulls out? Yes
Is there a box type thing behind the dash to? No
do I have to take the whole dash apart? No
Sorry for all the questions, thanks in advance, No problem
Hope that helps
Old Dec 31, 2002 | 05:09 PM
Thanks for the answers Terry
Old Jan 3, 2003 | 12:50 AM
when I go to the junkyard to get the heater only box will I just take what is on the firewall or is there stuff on the inside that I will need to?
Old Jan 3, 2003 | 10:51 AM
Car: 88 IROC
Transmission: pg
All you need is the box.
Old Jan 4, 2003 | 06:21 PM
sorry one more question, there is a heater box on ebay right now but it doesnt have the blower motor on it, can I use the AC motor or does it have to be a heater motor? Thanks again
Old Jan 5, 2003 | 09:13 AM
Car: 88 IROC
Transmission: pg
The motor's are the same but you will have to find a heater cage because it is smaller than the a/c cage.
BTW the cage is the plastic round wheel that is connected to the motor.
Old Jan 5, 2003 | 01:45 PM
thanks again terry , you seem to know every answer I have, I really appreciate it.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
redmaroz
Aug 16, 2015 11:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
