Finished LED Dash
Old Jan 12, 2003 | 09:59 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Finished LED Dash
Just finished converting my gauges to LED. They look good, hard to tell in the pics though. Here's a before pic.
Old Jan 12, 2003 | 10:00 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
After LED conversion
Old Jan 12, 2003 | 11:04 PM
92V6Heritage's Avatar
Hey I had an idea like that, how'd you do it and what lights did you use?
Old Jan 12, 2003 | 11:33 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Is your Service Engine light on in the second picture?
Old Jan 13, 2003 | 03:42 AM
Odyssey's Avatar
Uhhh... I think it looks like poop. The desired effect is this:
p.s. Yes... that is the dashboard in my car. That's an old pic. It looks ten times better now.
Old Jan 13, 2003 | 03:43 AM
Odyssey's Avatar
Now what you want to get that effect is to REMOVE your stock black overlays and use MacEwen's white/silver overlays instead. They're transparent and will the blue light through instead of turning it green like your stock overlays do.
Old Jan 13, 2003 | 03:33 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
92V6Heritage- I used 8 LED's two in each socket for the bulbs that illuminate the dash. The LED's were white ones, and cost me 1.75 a piece.
LowStyleII- yes my service engine soon light is on, but it isn't now, my car has been sitting in the garage and it went away after i ran the car.
Odyssey-If I had money to spend I would have done mine like yours. I got the white LED's, mine aren't blue, so its probably an illusion if you saw green. I only used 8 LED's, all in the dash lighting and not the warning lights. I probably spent a third of what you did. Again when I get the money I'll probably get the white face gauges, and maybe more LED's.
Old Jan 13, 2003 | 06:31 PM
JimmyG-91Z's Avatar
Thats Sweet!:hail: , did you do that the same way as in the tech article but with more LED's or is it from the MacEwen's overlays that makes them so bright, I want to make mine look just like that.
Old Jan 29, 2003 | 09:34 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I got some updated pics
Old Jan 29, 2003 | 09:36 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Old Jan 29, 2003 | 09:37 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Old Jan 29, 2003 | 09:38 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
4... last one
Old Jan 29, 2003 | 10:11 PM
dsaint1347's Avatar
Sweeeeeet!!!
How did you do that, do you have any install pics? Please show me:hail: :hail:
Old Jan 29, 2003 | 10:48 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Not bad, I'll stick with pontiacs orange though
Old Jan 30, 2003 | 12:02 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I see green too.
Old Jan 30, 2003 | 12:50 AM
roadog115's Avatar
Engine: L98 350 ci.
Transmission: 700-R4
Did you just take off the orange on the needles to make them white?
Old Jan 30, 2003 | 01:14 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I like it. Like roadog115, I too would like to know about the guages. that is the one thing missing from mine.
Brian
Old Jan 30, 2003 | 01:17 AM
FLYNLOW92rs's Avatar
Well maybe if you didn't spend all your money to fill up your gas tank, then you would have some money for LED's........lol.....
That looks good....
Odyssey - Who did your dash??
Old Jan 30, 2003 | 01:45 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
Odyssey: how many led's did you use?
how did you get the needles red?
what mcd where the leds you guys used?
Old Jan 30, 2003 | 04:55 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I'll get some pics of what i did for everybody. I basically did what the tech article said.
My car is the V6 Camaro, so the gauge needle's are white. See the needles on my spare dash, they are a yellow color. See picture.
I used something like 4000mcd white led's. I used two in each socket. I only used 8 LED's to illuminate the dash, Later on i will modify my dash so i can use more leds.
Old Jan 30, 2003 | 04:58 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Spare gauge cluster with yellow needles.
Old Jan 30, 2003 | 05:16 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I looked at the back of my tach and might be able to figure out how to make the needle a different color. I'll post pics if i can.
Old Jan 30, 2003 | 07:36 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
It seems that Odyssey is Blackened, the same guy who was supposedely selling the led kits for gauges...
Old Jan 30, 2003 | 08:07 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Ok, I bought one blue led and two red leds. I installed the red leds in my spare gauge cluster. It works pretty good and illuminates the tach needle red. I used a white led flashlight to illuminate the rest of the dash that. This is my spare dash so its not in my car yet. It was pretty easy. I used a dremel to cut the clear plastic so my white leds don't shine on the needle. then i used a drill to drill into the clear plastic around the needle. It was pretty easy and i used two and it is pretty bright. I'll try the blue led sometime and let you know how it turns out.
Old Jan 30, 2003 | 08:13 PM
Car: 86 Z28
Axle/Gears: TBD
i'm thinking about using ultra high leds to light my needles in orange. they don't have to me red for me.
is ther a light behind each needle.
Old Jan 31, 2003 | 05:46 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Got the red needle installed in my car. What do you think? I like it.
Old Jan 31, 2003 | 05:49 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
another pic
Old Jan 31, 2003 | 05:50 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Old Jan 31, 2003 | 06:01 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
OK, here is a pretty bad diagram on how to do this. thisi is the back of my spare gauges for my 91 RS. This should work on all 90-92 gauges. I hope this helps.
Their are 4 bulbs that illuminate the dash and the needles. So unless you do something like this your needles will be the same color as the led's behind the dash. I don't know what it looks like behind previous year camaros or firebirds dash and not sure if it would work. I got more pics i can email you if you want of how i got the needle to be red.
Old Jan 31, 2003 | 11:33 PM
burnouts4ever's Avatar
harry you gotta do all your needles
Old Feb 1, 2003 | 12:19 AM
Old Feb 1, 2003 | 12:48 PM
Quick6's Avatar
Originally posted by FLYNLOW92rs
https://www.thirdgen.org/techbb2/sho...hreadid=104827
Old Feb 1, 2003 | 01:54 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
i'd use white leds for the numbers and red leds for the needles. but since i'm too lazy to do that i'll stick with pontiac's orange.
Old Feb 1, 2003 | 02:17 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Brian
Thats........so.....beautiful! I.........must.......have.........done.......to.......mine.......how.......you.......do........that..........
Old Feb 1, 2003 | 09:20 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
on the t/a dash..
how did you change the defroster / hatch release buttton color?
Fronzizzle
Feb 9, 2017 09:31 AM
MantyZ28
Nov 8, 2015 06:54 PM
codeysabatini
Sep 20, 2015 11:36 AM
gta_knight
Sep 17, 2015 03:48 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
