Idle Learn Procedure
Old Jan 30, 2003 | 10:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Idle Learn Procedure for 3.1L V6 (auto only?):
Disconnect battery, wait one minute, and reconnect.
Turn off A/C.
Turn off Backlight Heater (rear window defroster).
Do Not Touch The Throttle at Any Point.
Do Not Touch The Steering Wheel at Any Point.
Set parking brake and chuck tires.
Start engine, let settle a bit and put trans in drive.
Let engine run until fan cycles on then off.
Turn off engine.
Wait five minutes.
Start engine and place in gear.
Let idle for five minutes.
Shut off engine.
End of procedure.
If the throttle is touched at anytime during this you have
to start from the 'disconnect battery' again.
If the steering wheel has pressure applied you have
If the engine stalls at any point just restart and place
back into gear.
RBob.
Old Jan 30, 2003 | 12:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by V6camarossucknu
the V6's are noctourious for running lean. Why make it run leaner?
Huh? How does setting the minimum IAC position make it run leaner? "noctourious", is that a word?
RBob.
Old Jan 30, 2003 | 12:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
the IAC will automatically set itself. no proceddure neccisary. I have rplaced 3 of them. Never had to do anything but unplug to comp, install the IAC, plug back in the comp and let it run for 10 minutes.
Sounds real close the the actual procedure. Still haven't explained why it would make it run leaner.
Maybe we should get a pool going on how long it takes you to get banned again, CHC.
RBob.
Old Jan 30, 2003 | 02:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
And I could care less if I get banned, can't you tell?
Then can't you be a real honest-to-goodness-human and just ban yourself? Must say, if anything you are keeping this post ttt.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
