modifying throttle linkage
I just got the Holley 670 cfm TBI for my 91 RS 305. While comparing this to my stock TBI, the throttle linkage doesn't look right. Do I have to modify this so that it will connect to the holley? I've searched around here but I haven't found any details or pictures on how this is done. Please help me.
Rene
91 RS 305 TBI
Rene
91 RS 305 TBI
Car: 91 Red Sled
It's stupid how Holley does it. I'm not sure why they do it this way, they say it's a direct install when it isn't! You have a couple options, one is perfectly fine and the other is better. The "okay" way to do it is to just hook it up even though the throttle and trans lines touch under WOT. Remember, trans is the bottom, cruise is the second from top, and throttle is the top. The other options is to hack saw the top one off and drill it out then replace it on the other side with a standard carb linkage part. All in all it's a royal PITA and I think Holley should be held responsible for their stupidity.
Car: 91 Red Sled
Originally posted by ZRATED
Is it possible to replace the holley throttle linkage with the stock one of the tbi?
Originally posted by JPrevost
Good question. At the time I didn't even think about taking it apart since it was brand new. I didn't figure it out until it was already bolted on and by that time I didn't care. I just wanted it to run.
later
tim
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
Car: 91 Red Sled
Originally posted by c4boom
just have to say that yes it is a direct bolt on for a truck i did it
I finally got around to installing my holley with the stock throttle linkage, it was a very simple swap. I just gound off the tab with a bench grinder of the the stock throttle linkage and took it off then i did the same for the holley. Then I just put the stock one on the holley, drilled and taped a hole in the middle of the rod and placed a little bolt with a washer to hold the throttle linkage in place. an it works great!!!
Michael:lala:
Michael:lala:
Magman
Sep 14, 2015 01:30 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
