High beam selector doesnt work with wheel in "down" position
Old Feb 2, 2003 | 03:38 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
I notice that my high beam blinker switch wont engage unless the steering wheel is up as high as it'll go. if i adjust it so its lower the highbeam will go on but wont "stick" on. if i adjust it all the way down it doesnt work at all. is this an easy fix or do i need a new blinker arm?
Old Feb 2, 2003 | 04:49 PM
llvll4l2c91350's Avatar
Try adjusting the high beam selector switch under the dash. It should be a white plastic piece with a metal rod going to it. It will be a pain to get to it but you should be able to see the rod move when you push the lever. There are two screws that you need to loosen up to adjust. I had the same problem where it wouldn't lock. Adjusted it and fixed it.
Old Feb 2, 2003 | 05:44 PM
TekViper's Avatar
Engine: 3.1L v6
thanks i'll try that. by under the dash u mean under the knee pad part?
Old Feb 2, 2003 | 06:39 PM
Yeah up by where the ignition switch bolts to the column.
Old Feb 2, 2003 | 07:20 PM
TekViper's Avatar
Engine: 3.1L v6
thanks again, i'll look for it next time i get a chance.
Old Feb 9, 2003 | 02:37 PM
TekViper's Avatar
Engine: 3.1L v6
ok i see the little white thing that clicks when i move the lever but i cant figure out where u adjust it? any help?
Old Feb 9, 2003 | 03:56 PM
I believe it's held on by two screws that are a pain in the *** to get to. IIRC I used a shorty 10mm wrench. I only loosened the one I could actually reach, and was able to move it enough for adjustment.
Old Feb 9, 2003 | 04:02 PM
TekViper's Avatar
Engine: 3.1L v6
alright, sounds like a pain. couldnt even see the screws at all. i'll go out and get a better look.
Old Feb 9, 2003 | 05:05 PM
TekViper's Avatar
Engine: 3.1L v6
that fixed it! there was two 8mm bolts on it, i couldnt even see one but managed to get the wrench on it. thanks alot man i would have never been able to figure that out on my own
Old Feb 9, 2003 | 05:24 PM
Awesome
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BBSDesigns
Aug 11, 2015 07:39 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
