Wonder Bar Installation Problem
Old Feb 13, 2003 | 03:16 AM
KenGTA88's Avatar
Has anyone installed a wonder bar with the stock dual electronic fan setup? I just bought an adjustable wonder bar from Spohn and the bar hits the plastic base mount for the fans so it can’t be installed. I’m probably going to end up remounting the fans out of the way this weekend but I was just curious if anyone had the same problem and how they fixed it.
Old Feb 13, 2003 | 05:52 AM
BILZ88350's Avatar
I installed the BMR one with the same problem. I elongated the bolt holes on the bar so that I could move it away from the fan supports.
Old Feb 13, 2003 | 10:40 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went through the same problem. I was pretty pi$$ed. I had to cut , notches into all 4 mounts and drill out the holes bigger on the driver side , bend in the PS cooler lines , notch out 1/4 on the bolt holes in the pass side and bend the factory tab from the SW brackets on the pass side. It was far from a bolt in idea from my stock wonderbar.
Old Feb 14, 2003 | 01:40 AM
KenGTA88's Avatar
Thanks for the insight guys. It looks like I'im in for a lot of work this weekend.
Old Feb 14, 2003 | 07:20 AM
92camaro44's Avatar
well if you guys have the wonder bar..i have a qtn...will this help my steering radius?..it seems very hard for me to bust out u-turns..and it seems to get worse..i put new tires on the front and new center-link..any suggestions??thanks :hail:
Old Feb 16, 2003 | 12:54 AM
MdFormula350's Avatar
thats alot of work just for a "bolt-in" piece!!
Old Feb 20, 2003 | 04:27 AM
KenGTA88's Avatar
I dont know about it helping your turning radius? The wonder bar is made to stiffen up the front sub-frame and reinforce the steering box mount. Needless to say I got the wonder bar on my car. I ended up taking off the fan mounts and shaving them with dremel tool for clearance away from the radiator.
Old Feb 20, 2003 | 02:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine went in with no problems, I have the GM Wonder bar and not an adjustable. Can you post a pic similiar to mine so we can see what problems you had?
Old Feb 20, 2003 | 05:38 PM
Tom Keliher's Avatar
Mine fit with the stock dual fan set up, no problem:
Old Feb 20, 2003 | 06:20 PM
BORLAZ06's Avatar
mine fit fine...but all cars are different.
Old Feb 20, 2003 | 08:02 PM
MikeS's Avatar
GM one fit fine for me. For whoever asked about turning radius....
it won't help at all. The wonderbar reinforces the chassis structure that the steering box is bolted to by connecting it to the corresponding section on the passenger side of the car. I have had cracking problems around the steering box before and feel that the wonderbar is a necessary structural member on our cars to prevent that. Others advocate it as a handling modification, I say get one as a longevity/durability modification.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
