Braided fuel line
Old Mar 11, 2003 | 10:07 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Braided fuel line
I have my fuel rail all ripped apart to polish do a few things to. But i fought for at least 2 hours trying to get the fuel lines out of the rail, with no success. But I was wondering if I can run braided fuel line all the way to the FPR w/o problems. Also has anyone done it? Is this a good way to go? all I'm looking for is to get rid of those pain in the butt stiff stock lines and replace them w/ some flexible braided line. Thanks for any comments
Jason
I have some pictures but the quality is sooo bad I didnt post them. let me know if pics would help the explaination.
Old Mar 12, 2003 | 01:32 AM
Bort62's Avatar
All the way to the AFPR ?
Why not just to the Fittings on the rail ?
Old Mar 12, 2003 | 07:02 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I wanted to eliminate the stiff lines all together!!
Old Mar 12, 2003 | 07:32 PM
Bort62's Avatar
Eh well good luck... lol
Old Mar 12, 2003 | 07:45 PM
leirch's Avatar
The way Bort has it done is probly the only thing you can do with retaining the stock fuel rails/stock TPI setup.
Old Mar 12, 2003 | 07:52 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
bort you got a part number for those 2 fittings id like to swap to braided lines for mine,thanks.
Old Mar 12, 2003 | 10:04 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
well maybe I will just do that then...so bort how long are the lines? And yea what are the part # for the fittings.
Old Mar 13, 2003 | 01:02 AM
Bort62's Avatar
I got all my stuff through Speedtoys.com - it's XRP fittings and line.
I don't have the Pn#'s off hand but if you contact Jeff at Speedtoys he can take care of it.
One thing to note, is that TPIS is the only company i could find that has the Female saginaw x -6AN fittings you need for the framerail side, so you will ahve to get that part from them to screw into the factory framerails.
Old Mar 13, 2003 | 05:58 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
thanks for the reply
Old Mar 16, 2003 | 03:37 AM
89ProchargedROC's Avatar
Hey...i have one of the fittings you need. Its like a $7 fitting..i'll sell it to you for $5 shipped
Old Mar 16, 2003 | 12:04 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
This is what you need: Jegs Part number 310-74730
Summit part # ACC-74730
This will allow you to connect AN fittings to the fuel rail.
For the lines coming from the tank you will need Earl's 9894DBH and 9894DBJ fuel fittings
Summit part #'s: EAR-9894DBJ, EAR-9894DBH
Old Mar 16, 2003 | 01:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Do something like this..
Then just mod the lines back by the firewall and your all set.
6an return and 8an feed
plug the front.
Old Apr 3, 2003 | 03:43 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I used the following part #'s to make factory hard lines -6AN fittings.
1 991954 Fuel Injection/Power Steering Adapter. Male O-Ring Seal 6.66 6.66 T
1 991955 Fuel Injector/Power Steering Adapter 6.66 6.66 T
1 9894DBH 14x1.5mm to -6 Male Adapter 5.87 5.87 T
1 9894DBJ Female Saginaw to AN Male Adapter 5.87 5.87 T
Shipping Shipping 10.50 10.50
Out-of-state sale, exempt from sales tax 0.0% 0.00
Total
$35.56
Those are all Earl part numbers. I then used Earls braided hose aprox. 2 foot lenghts for feed and return and a 2) 90 degree swivel -6AN fittings for fuel rail side and 2) 110 degree swivel -6AN fittings for the hard lines on the driver's chasis. I had to modify alternater/p.steering bracket to run them up over top of engine. I will post pics after i insatll them.
Old Apr 3, 2003 | 07:47 PM
88GTAinRI's Avatar
Engine: Blown 355
991954 & 991955 installed to fuel lines on frame.
Old Apr 3, 2003 | 07:48 PM
88GTAinRI's Avatar
Engine: Blown 355
9894DBH & 9894DBJ installed on fuel rail.
Old Apr 3, 2003 | 07:49 PM
88GTAinRI's Avatar
Engine: Blown 355
Braided lines to fuel rail.
Old Apr 3, 2003 | 07:50 PM
88GTAinRI's Avatar
Engine: Blown 355
Braided lines to tubes on frame.
Old Apr 3, 2003 | 07:51 PM
88GTAinRI's Avatar
Engine: Blown 355
Finished view.
Old Apr 3, 2003 | 10:34 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
wow thanks for all the good info I think I will tweak with that then
Old Apr 5, 2003 | 09:44 AM
Vader's Avatar
When you get all finished, and the engine is running like you want, cut your original fuel linse apart. Don't be too surprized to find reinforcement wire in the hose. After dealing with 10,000+ PSI hydraulic hoses in all kinds of operating environments, I still can't understand the desire for an UNCOVERED outer reinforcement braid. Those things are avoided like the plague in almost any other application, since the exposed braid is actually a weakness.
Then again, I'm probably spoiled. When you TRY to blow up hydraulic cylinders and accumulators at 15-18,000 PSIG, you use the best parts you can get....
Old Apr 5, 2003 | 10:40 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Blue and red fittings with stainless steel braid looks way better than a nasty rubber hose.
Old Apr 5, 2003 | 11:09 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Vader,
The hose I use also has a half braid going through it too.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
