Strange noise coming from under the hood after supercharger install
Old Mar 13, 2003 | 09:32 AM
89IROCZZ4's Avatar
While, one strange sound, the whistle is nice and I wish I could hear it all day long, another sound concerns me ....
I have been noticing some type of a chirping/ticking noise from under the hood. When it was colder out (40°) I didn't noticed it much but now that it is always 60° +, it seems to happen more. I have had 2 possible diagnosis: 1. It could be a belt/pulley or 2. It could be a bearing/race in the supercharger. Any ideas? Has anyone gone through this? Any info would be greatly appreciated. Thanks!
Old Mar 13, 2003 | 09:12 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
ummm did u check the inside of the supercharger to make sure that the teflon on the roters whernt flaking? i have this kind of problem with my eaton m90 and im trying to fix it (have no idea where to start thou)
Old Mar 13, 2003 | 09:32 PM
89IROCZZ4's Avatar
Actually, no I didn't check the inside of it. One thing that is interesting is that they said they put WD40 on the belts, and now there is no more sound like that. Hmmm... any thoughts?
Old Mar 13, 2003 | 10:42 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i'd think that would make the belt slip bad...maybe try a LITTLE vht
Old Mar 13, 2003 | 10:46 PM
89IROCZZ4's Avatar
vht? what is that?
Old Mar 14, 2003 | 12:05 AM
True Power's Avatar
Same stuff they spray on the dragstrip, make it a bit more stickier
Old Mar 18, 2003 | 12:53 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have noticed a phenomenon that I have discussed with a few blower manufacturers. As I have seen and as it was explained to me, the gears that drive the blower rotors occasionally chug, this is true on centrifugals as well. It comes usually at idle from an occasional and random misfire or power impulse that is not even. through the sound of the gears it is greatly amplified and can sound as if something foreign is running through the drive gears or like it is binding. Running rich (or lean), big plug gaps, worn: plug wires, cap, or rotor can aggrivate this problem. Let me know if you think this is what you are talking about. I have also seen a idler bearing failing cause this so go figure...
Old Mar 18, 2003 | 02:27 PM
89ProchargedROC's Avatar
centrifugal superchargers dont have teflon coated blades like the eatons do.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
red90IROCls1
Aug 25, 2015 06:56 AM
bryan623
Aug 10, 2015 11:33 AM
