Need help wiring parking lights
Old May 1, 2003 | 05:52 PM
skahide's Avatar
Ok, i have an idea and need help. Imagine you turn on your parking lights. Then when you turn on your turn signal the buld flashes brighter than without the signal on. Ok, now how can i make it that bright all the time then when blinker is on it just dims instead of brightening? Is it possible?
Old May 1, 2003 | 10:59 PM
Tyler-88's Avatar
got one wire for your marker lights, one wire for your turn signals, cant you just swap the two around? id do it right where it comes out of the car, just below your brake booster.
Old May 1, 2003 | 11:20 PM
skahide's Avatar
do you mean marker lights as side marker? if so, basically switch the front turn signal light wire and the side marker light wire?
Old May 1, 2003 | 11:22 PM
skahide's Avatar
1 More question, where and what is the booster? Firewall area? thanks, pic would help if it isnt to much trouble. thanks
Old May 3, 2003 | 11:59 PM
skahide's Avatar
No one else can help me? I really wish that i could do this. It would kick butt. thanks
Old May 4, 2003 | 04:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I have to admit (inset my stupidity), I'm at a loss for what you're asking
Old May 4, 2003 | 09:45 PM
skahide's Avatar
OK ill try to restate this. ok when you turn on the parking lights the front bumper parking lights light up. then once you turn on a blinker those same lights blink brighter. is there any way that instead of it being dim with out the blinker, that it could be bright all the time as if the blinker was stuck on. Hope that helps.
Old May 4, 2003 | 11:01 PM
deadbird's Avatar
Engine: TPI 305/ v6
So you're basically wanting a daytime running lights (DRL) like on a 4thgen ?
Here's a diagram to do it using 3 relays (per side) which can easily be obtained at the junkyard.
BRoss99
Aug 10, 2025 05:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
