FIRST TPI, ever heard of these???
Old May 16, 2003 | 12:16 AM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
I was just checkin out some stuff on ebay and I came across this
http://cgi.ebay.com/ebaymotors/ws/eB...category=33553
Was wondering what their capabilities were? they look like they flow a lot better than even a ported TPI unit because the runners are ENORMOUS. anyone have of them? They interest me cause I've NEVER heard of it! Apparently they are alright, shed over a second off this guys time http://home.att.net/~ncarboni/NCtpi.html
anyways, just wanted to know what the hell the thing was! later!
Old May 16, 2003 | 12:37 AM
Guest
Guest
Posts: n/a
Old design, new guy taking over what for a long time was dead.
I think its way overpriced. Go buy a stealth ram, or port your stocker.
Old May 16, 2003 | 08:56 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
it s a newsetu i've never seen. but i don't think its worth $950
Old May 16, 2003 | 09:05 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
those ports are freaking huge. For the money I'd still go stealth-ram, but that setup does intrigue me.
Old May 16, 2003 | 10:05 AM
Car: '88 IROCZ
I've got a mini-ram on vortecs, not interested in buying it, interested in learning what it is and how well it performs.
Old May 16, 2003 | 08:44 PM
BadSS's Avatar
I believe it was originally made by Air Sensors and sold as a stand alone unit with their own ECM that did not control the ignition curve. The 3" mono-blade T/B (that can be side mounted) and the 4" MAF that came with them sure could deliver a lot more air than the stock TPI. As you can see in the Ebay photos the intake base ports are HUGE compared to the stock unit and replacement units. While the runner diameter is much larger, the length was/is similar to the stock TPI and the unit gives good power down low and didn't seem to have "the wall" associated with other LTR set ups - per old dyno tests. It was not very popular "back when" due to it's $2500 price tag,, and you could not get just the base, runner, and plenum back then - I tried.
The intake, runners, and plenum are the same as the old Electromotive units,, if that means anything to you. However, I believe the Electromotive units used a speed density system with O2 sensor and that ECM controlled a distributor less ignition - you couldn't get just the base, runners, and plenums from them back then either.
As far as power, they usually produced similar,, but slightly better curves than the SuperRam intakes - better low end and similar (usually better) high end - the base intake design is at a better angle than the stock, Accel, and Edelbrock base. I would buy the base, runner, plenum, and T/B if the price was right (not at $950),,,, and could get a TPS rigged on it to work with the factory ECM.
HTH
Old May 16, 2003 | 09:35 PM
Car: '88 IROCZ
found the website for it
www.firstinjections.com
some good info on it. the ports are 1 3/4" and can be ported to 2" if you want to! The manifold itself goes for $995 and they are making one for vortec heads so it's not a thing of the past. I think it's cool, it can handle up to 6500 rpms, and looks like a relatively stock TPI unit to the untrained eye (i.e. mustang owner ) That'd be great for a wild motor with a stock look!
Old May 16, 2003 | 11:07 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
hmmmmmm bookmarks that site
thanks
Old May 17, 2003 | 12:16 AM
Car: '88 IROCZ
no problem f-crazy. It's supposed to flow as well as a superram, which is plenty of breathing, and it looks very much stock! I wish I knew about this when I was building my motor!!!
Old May 17, 2003 | 02:05 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
wouldnt it still have the limitations of TPI, which seems like every one is getting away from? if ever were to build a 396 stroker or a 406 that first injections design was on my list but i talked to someone about it and they said the limitations of teh TPI would still be there.
Old May 17, 2003 | 05:43 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
On the second link,noel is a member of the corvetteforum,hes had it on there for a few years now,and runs pretty good with street tires @ 12.85 @ 111 mph! with a 418 ci.
Old May 17, 2003 | 09:14 AM
Car: '88 IROCZ
yeah, the limitations would still be there, they'd just occur at 6500 rpm instead of 4500 rpm.
MustangBeater20
Oct 29, 2022 09:20 PM
bjpotter
Jan 22, 2019 12:27 PM
19irocz85
Aug 26, 2015 07:54 PM
trevor1010
DIY PROM
Aug 24, 2015 11:29 AM
Sanjay
Aug 12, 2015 03:41 PM
