Header and starter heat shield...pics inside
Old Jun 9, 2003 | 09:51 PM
RICHRAD's Avatar
Well, before I could mount the heat shield I had to bolt up the starter ,then reattach the wiring to position it away from the header. To put the heat shield on, I then had to add some slack up top and unbolt the starter , drop the starter way down with wiring attached, then bolt on the shield. It all fell right bak into place and the Hedman header stayed nicely out of the way!
Attached Thumbnails Header and starter heat shield...pics inside-p6090006.jpg
Old Jun 9, 2003 | 09:53 PM
RICHRAD's Avatar
a nudder one
Attached Thumbnails Header and starter heat shield...pics inside-p6090007.jpg
Old Jun 9, 2003 | 09:57 PM
RICHRAD's Avatar
Hard to tell from this pic , but the top of the shield folds up over the solenoid and wiring
Attached Thumbnails Header and starter heat shield...pics inside-p6090005.jpg
Old Jun 9, 2003 | 10:01 PM
RICHRAD's Avatar
Seen some serious down time....but not for long
Attached Thumbnails Header and starter heat shield...pics inside-p6090008.jpg
Old Jun 9, 2003 | 10:52 PM
BTS88IROC's Avatar
Nice work! Did you make that yourself?
Old Jun 9, 2003 | 11:55 PM
25THRSS's Avatar
yeah, nice work.
Old Jun 10, 2003 | 02:37 PM
bigals87z28's Avatar
Car: Check The Sig
do you really need to worry about heat soak when you have headers that are coated? I dont have any plans to put one on my starter... maybe i should for extra protection...
Old Jun 10, 2003 | 04:12 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I was thinking about doing the same thing with mine. My car has been down for a few weeks now also hehe up on car ramps and all. I just reran all the wires so they will be safe from the headers they were to close for me in some places.
Old Jun 10, 2003 | 05:19 PM
RICHRAD's Avatar
It's a Moroso starter heat shield #74300....Yeah, didn't think about the coating saving the starter
Old Jun 11, 2003 | 06:31 PM
Dan88IrocZ's Avatar
I guess so! LOL I was looking at the heads and I was like wow those things are bone dry!
Old Jun 11, 2003 | 06:39 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
My headers are coated but that didn't save my started...ended up putting a GM mini starter on after the heat killed my other one and put a heat wrap on it. The wrap/shield is definately worth it.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
