Bad smell
Old Jun 7, 2003 | 04:20 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
Bad smell
hey guys, well ive been noticed lately that if i go though a drive thru i smell bad smell, but ive been thinking, " its not my car cause i dont smell it other times" but now i park in the garage. i smell it everytime i pull the car in after ive drove it atleast 5 minutes, anytime under 5 minutes theres no smell. Ive heard it said before that the bad smell means the catalyaic converter is bad....is that true? i dont see any other problems with it, no rust holes, doesnt seem to be clogged. i have one exhaust leak just before the muffler if that matters any.
Old Jun 7, 2003 | 06:48 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
It is probably a clogged cat. As it heats up it will get worse. I'm not sure if there is a way to verify it other than remove the cat.
Old Jun 7, 2003 | 06:56 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
if it smells a little like rotten eggs its time to change the cat.
Old Jun 7, 2003 | 07:39 PM
Transmission: autos
well right now i have no money to buy a new cat, im about to start work next friday so then i can replace the cat and my fuel filter. what can i mess up drive it with the bad cat? what caused it to go bad?
Old Jun 7, 2003 | 09:27 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
If I'm not mistaken that is caused by running too rich.
Old Jun 8, 2003 | 01:56 AM
25THRSS's Avatar
For the time being you can gut it.
Old Jun 8, 2003 | 09:04 AM
Transmission: autos
its odd though because, my car has the smell but still runs perfect, while my moms explorer which i know has a clogged cat, the exhuast is barely getting out and it has the bad smell, my exhuast is still comming out like it should
Old Jun 11, 2003 | 06:52 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
There's no way your cat would be completely clogged. If it were the car would stall out. This doesn't me the it's not clogged up a little though. Either way, it's not a good thing. You could go to the dyno and get an A/F reading. I bet it will be rich.
Old Jun 11, 2003 | 06:55 PM
Transmission: autos
the "i know it all cause im a r1cer guy at autozone told me my cat was fine, but he couldnt figure out what the codes i was gettin meant...lol dumb guy
Old Jun 11, 2003 | 07:04 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
codes? What codes are you getting?
Old Jun 11, 2003 | 07:08 PM
Transmission: autos
im not sure..lol he couldnt figure it out, now i gotta wait for the light to come back on and do it myself. do u know if the codes are the same for 4th and 3rd gens?
Old Jun 11, 2003 | 07:30 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hmm
No Distributor pulses
Oxygen sensor
Coolant Temp sensor circuit
21
Throttle Position Sensor
22
23
Manifold Air temperature sensor
24
VSS (Vehicle Speed sensor)
25
32
EGR system
33
MAP sensor or MAF sensor depending on engine
34
35
Idle Air Control Valve
36
MAF Burn-off circuit
41
No Distributor pulses, cylinder select error
42
Electronic Spark Timing or Bypass fault
43
Electronic Spark Control fault
44
Lean exhaust
45
Rich exhaust
46
VATS system fault
51
PROM fault
52
CALPAK fault
53
System over-voltage
54
Fuel pump circuit
55
ECM fault
61
Oxygen sensor fault (degraded sensor)
Old Jun 11, 2003 | 07:36 PM
Transmission: autos
thanks z28monster
Twin_Turbo
Mar 14, 2016 10:10 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
Blue419
Sep 10, 2015 01:03 PM
