Pics of my hidden Amp Install
Old Jun 10, 2003 | 06:15 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Before. I just laid the amp in the trunk and ran the wires to it. Worked great, but I couldn't use my trunk anymore. So it had to go.
Testing. It's a Crunch with 4x 75W RMS that powers my Infinity Kappa 4x6" and Infinity Reference 6x9" speakers.
The new location. I still keep my spare tire and the glove box.
Done. Where's my amp?
Old Jun 10, 2003 | 06:41 AM
napalmdemos's Avatar
Car: 91 Firebird
Good idea, but does the amp still get enough air to keep it cool?
Old Jun 10, 2003 | 06:53 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
It didn't get hot in the trunk so I guess it should work. If it doesn't I'll mount a 12V fan in the box.
Old Jun 12, 2003 | 02:19 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Fixed the images. I must have accidentally deleted them from the server.
Old Jun 12, 2003 | 10:25 PM
CaysE's Avatar
Hey man, that spot is perfect. I think I may do that myself. Class D amp for me, so the cooling won't be too much of an issue. I think if you just cut some slats into the cardboard storage compartment, you'll get enough air. Or like you said, hook up a 12v fan.
Old Jun 14, 2003 | 04:26 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
.:hail:
i will be doing that as soon as i get an amp. but i do have a few questions, how did you atach it to th fender. wouldent screws go through ad stick out the other side of the car? or is it a double fender?
Old Jun 14, 2003 | 05:42 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
I didn't use screws. I glued some sound dampening stuff to the fender to prevent rattles, laid the amp in place and installed the wood to hold it there.
Old Jun 14, 2003 | 05:51 PM
Xophertony's Avatar
Axle/Gears: n/a
ohhhh, like spry on foam insilator, or somthing. smart. thanks.
Old Jun 14, 2003 | 07:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
this is a rack I got from a friend.
Old Jun 19, 2003 | 10:07 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Looks nice and clean. I guess you trust your weatherstripping.
Old Jun 22, 2003 | 12:02 AM
onebadwagon's Avatar
is that an old punch 360? those amps kick ***.
adam
Old Jun 25, 2003 | 09:30 PM
slayer6x6's Avatar
Looks good man, i did the same thing to my car.
Old Jun 26, 2003 | 03:15 PM
MdFormula350's Avatar
thats a great install, nice work.
Old Jul 14, 2005 | 08:40 PM
Xophertony's Avatar
Axle/Gears: n/a
wow, a bit of a necro post, but i see the pictures are gone, i happened to save one of them from when i read this long ago, here is the pic
Old Jul 14, 2005 | 08:58 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
nice that the spare tire compartment or the place under the cardboard compartment? Looks weird without all that trim.
Old Jul 14, 2005 | 11:25 PM
Xophertony's Avatar
Axle/Gears: n/a
behind the glove box. nice idnt it?
Old Jul 21, 2005 | 08:22 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
ought to put a good lock on that box so if some bastard decides to bust out your back window, he'll have to take the entire thing to get your amps.
Old Jul 21, 2005 | 08:52 PM
Zepher's Avatar
just curious, why did you dig up a 2 year old post and post a pic from that install?
Old Jul 21, 2005 | 11:09 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
he dug it up because the images disappeared.
you could always try something like this... I get to keep the spare, AND the glovebox.
Old Jul 22, 2005 | 05:14 AM
Xophertony's Avatar
Axle/Gears: n/a
i dug it up because i refrenced it in another thread and realised that when folks clicked to look back at the old post they would not see pictures and never know what i was talking about.
also, if you searched and found this page (like i did when i thought about "that cool hidden install i have a picture of") and everyone is raving about how awsome it is and there are no photos you would be like "awwwww!" so i fixed it as a public service.
a;so in this perticular install the amp is behind the glovebox, you still have FULL USE of your glovebox. one drawback is that you must remove that pannel in order to anjust anything.
Old Jul 22, 2005 | 10:24 AM
Zepher's Avatar
But there aren't any pictures here besides the one you attached. Couldn't you have attached that picture in the thread you were originally in?
Old Jul 22, 2005 | 12:58 PM
ScrapMaker's Avatar
how much space is there behind the original glovebox to fit an amp in there? why wouldn't they have just made the glovebox bigger?
Old Jul 22, 2005 | 01:49 PM
Xophertony's Avatar
Axle/Gears: n/a
i did attach the picture in the other thread as well. but when i saw that the picture was gone from here i figured if anyone ever searched for "hidden amp" they would wan't to see the picture.
why wouldent they make the glovebox bigger? because they suck
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
sonu1975
Aug 11, 2015 08:38 AM
