On the bottle
Old Jun 13, 2003 | 06:00 AM
Diablo3Z28's Avatar
Car: 1986 Camaro Z28
Engine: Built Vortec 350
Transmission: 700 R4
On the bottle
For those of you on the bottle, where do you have it mounted?? I'm thinking of putting my car on the bottle. I'm looking for some ideas of where a good place to mount it would be and what to look out for. Any help or ideas would be greatly appreciated :hail:
350 Carbed engine, Forged pistons, no leaks. Motor was just rebuilt (haven't started it yet since rebuild) Hooking everything back up now.
Old Jun 13, 2003 | 10:46 AM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
Spare tire well..nice and easy.
Old Jun 13, 2003 | 10:58 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
What if you get hit from the side??
Old Jun 13, 2003 | 11:21 AM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
If we all worried about the what if's? in life..we wouldn't street race?or jump on it full throttle on back roads?...etc etc.It fits..it works..I'll worry about it when that time comes.
Old Jun 13, 2003 | 12:04 PM
Car: 91Z
Relax big guy, the ONLY reason I ask that is because that was where I wanted to place mine, I thought since you have already done this that you may know something I don't!!
Old Jun 13, 2003 | 12:16 PM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
I wasn't trying to be a dick..I may have worded that wrong.No offense intended or taken.I put mine there to conceal it the best and easiest way possible.I know what you know really..no tricks with where it is located.At the time I installed it I didn't want a bottle sitting behind me on the cargo shelf or in place of one of the rear seats.If the bottle vent decides to open for whatever reason I want it is far away from me as possible..I would rather it vent back there than 1 foot behind my head.For that reason I will live with the what if I get hit factor.
Old Jun 13, 2003 | 12:59 PM
Diablo3Z28's Avatar
How's that been working for you having it back there?? Run into any problems with installation? I've just been trying to figure out the best spot to put mine
Old Jun 13, 2003 | 01:37 PM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
A little PITA to get the bottle in and out sometimes but other than that not to bad.NX supplied a long enough feed line to reach the juice noid on the motor so that helped out alot..actually have a little extra slack which is nice.I have seen a few other N20 manufacturers that didn't supply a feed line long enough to mount it in the spare well.Maybe that is why others mount the bottle in the back seat and such?!And I like it in the well as it is out of sight..and direct sunlight.Installation was easy..mounting the noids was the hardest part as I wanted a custom setup.
Old Jun 13, 2003 | 01:39 PM
Diablo3Z28's Avatar
cool. You're running the NX system. How much did it cost you? and how much nos you running
Old Jun 13, 2003 | 01:57 PM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
NX Hitman Plus system..$450.150 shot..sometimes 200..motor was built to take a 250
Old Jun 13, 2003 | 02:18 PM
Diablo3Z28's Avatar
Cool. Thanx for the info. Hmmm I wonder how much my engine can take
Old Jun 13, 2003 | 04:39 PM
Kiwi-85IROC's Avatar
A tyre well mounted Bottle is safe, tidy and concealed. If you ever manage to get hit from behind and the bottle top does rupture off, the bottle will want to go down , not fly up as the pressure will be focused towards the roof, forcing the bottle to want to travel down. So its as safer place as any to mount it inside a car.
Old Jun 13, 2003 | 07:10 PM
Mark W. Winning's Avatar
At least if you get hit you will catch a real good buzzzzzzz
Old Jun 13, 2003 | 11:46 PM
TexasLT1's Avatar
Car: '92 RS
I thought the additive in automotive N20 was supposed to make you sick? :shrugs: who knows, maybe it would be enough of a buzz to make you forget about the damage to your car.
Old Jun 13, 2003 | 11:50 PM
Err what I failed to mention was if there was a fire the Nitrous might help feed it by giving it an oxygen boost!! ROFL
As they say " Its better to burnout than it is to fade away"
Happy spraying mate
Old Jun 14, 2003 | 03:33 AM
onebadwagon's Avatar
i wouldnt see there being a problem with the bottle back there.
lets all remember the fact that nitrous is NOT flammable, so the only time i would be worried, would be when the gas tank is on fire.
if the fire does not have anymore fuel to feed it, the nitrous isnt gonna do a whole lot, and the chances of the bottle bursting are slim, once again UNTIL the car is already on fire.
so kids, when the junks on fire, get the hell out, as if it wasnt obvious enough.
adam
Old Jun 14, 2003 | 09:22 AM
BOTLFED's Avatar
Here's mine.. Within reach at all times...
Cheers,
Old Jun 14, 2003 | 09:55 AM
Rhoadster01's Avatar
I was thinking about mounting mine there, but they won't let that fly at the track, will they?
Old Jun 15, 2003 | 01:35 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
they will if you run a safety blow down tube.
Old Jun 16, 2003 | 07:11 AM
Car: 91Z
Sorry about the rude reply onebad82z, now that I see all of the people on here saying it would not be too bad, I think I will give it a shot. Thank's guy's.
Old Jun 27, 2003 | 12:20 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
how about mounting it right behind the rear seats,also does anyone know how much feed line "NOS" gives you because im going to buy a kit in about 3 weeks for my 305 tbi.
That should help me at the track.
Old Jun 27, 2003 | 02:27 PM
a -6 15 foot line, like most Bigger kits use, will hold 1 lb of nitrous, so everytime you disconnect it, you lose 1 lb.
adam
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dusterbd
Sep 29, 2015 08:40 AM
Fox118
Sep 1, 2015 04:07 PM
fonzie85
Aug 13, 2015 11:50 AM
FlyinLow89
Nov 12, 2001 02:35 AM
