Problem with heater vents.
Old Sep 25, 2003 | 01:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Not sure if this is the correct place to post this, but figured I'd see what sort of response I get.
I have a problem with the vents for the heater in the car. I can turn the fan off, and have air blowing out of the windshield demist vents but when you select it to blow air from the vents into your face it still continues to blow out of the windshield vents. I can also change from hot to cold air.
Any ideas on what is wrong here? It's not a major problem but something I'd like to sort out.
Thanks for the help
Robert
Old Sep 25, 2003 | 02:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All of the little doors that route the air flow require vacuum. The rest position (in the complete absence of vacuum) routes it all to the defrost duct.
Sounds like the vacuum supply line is disconnected, or the vacuum selector switch on the control head is bad.
Old Sep 25, 2003 | 02:36 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
RB nailed it again! my beretta did the exact same thing except everything came out the front dash vents
Old Sep 25, 2003 | 02:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Well I have noticed something. The vacume line that goes to the heater control valve. Well, there is another comming out from the same place but goes to nowhere. I'm thinking this could be the vacume supply line. Anyone have any idea where this one goes to? Exact same as the HCV line only slightly longer.
Thanks again
Old Sep 25, 2003 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If this is under the hood, and the 2 lines are coming through the firewall right below the heater hose nipples in a harness with the A/C and blower wiring, that would be the line in question.
It should go to the vacuum reservoir, which might be a ball with 2 vacuum connections, or it might be a long narrow half-cylinder kind of thing. One of the connections (the larger one) on the reservoir should go to a nipple on the intake mainfold, and the one from the harness above should go to the smaller one.
Old Sep 25, 2003 | 03:20 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
doh you just solved my problem too!!!!!!!! Ive been having the same prob for a week and just remembered I took that plastic ball out a couple weeks ago.
Old Sep 25, 2003 | 03:32 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
This sounds like it!
Think I know what you are refering to here. 2 pics I found on the board:
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Old Sep 25, 2003 | 03:34 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Larger version.
I'll have a look tomorrow and try to plug it in somewhere and see how it is on my way to work.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
