A/C delete on the cheap
Old Oct 6, 2003 | 07:33 PM
88TAJeff's Avatar
Car: 88 T/A
I decided to pull the A/C on my car today since the pump has been making this horrible rattling noise for the last couple months. However, I didn't treasure the thought of spending $120.00 CAD on an A/C delete pulley.
So, I got a shorter belt and just bypassed it. It works just fine, and the tensioner still provides tension.
The only thing I have left to do is put a little 'bump stop' on the tensioner so it provides a little more tension. After that, it will be perfect!
Attached Thumbnails A/C delete on the cheap-engine.jpg
Old Oct 6, 2003 | 08:21 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
so uhh...hows your voltage? i bet if you turn your turnsignal on, the volts drop down to 10 with each blink!
Old Oct 6, 2003 | 08:27 PM
88TAJeff's Avatar
Car: 88 T/A
Nope, no voltage drop at all. The belt is actually quite tight as it is, about as tight as stock. And I can pound my stereo ( JBL BP600.1/ kenwood 120 x 2) with no ill effects so far.
Anyone else?
Old Oct 6, 2003 | 08:37 PM
llvll4l2c91350's Avatar
im sure it works, i just dont like the look of that big empty bracket. the A/C delete pulley even though it doesn't have to be used, gives the engine compartment look kinda cool.
Old Oct 6, 2003 | 08:43 PM
Car: 1990 Iroc-Z
Anyone else?
sweeet!
wish i could say the same, you should get that crappy smog pump outta there now.:rockon:
88TAJeff's Avatar
Car: 88 T/A
I know, as soon as I took the A/C out, I thought- that's ugly, but at least the rattling is gone.
Old Oct 6, 2003 | 11:13 PM
MelloYello's Avatar
What you did was interesting, but now you have no way to remove the smog pump and retain the serpentine setup unless you install an idler pully somewhere. I paid $47 for my AC-delete pully shipped. My engine bay looks really clean without the smog pump and A/C setup. I forget the URL, but do a search and you will find it. Good luck with your car.
Old Oct 7, 2003 | 12:15 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
https://www.thirdgen.org/techbb2/sho...hreadid=202764
Old Oct 7, 2003 | 09:08 AM
88TAJeff's Avatar
Car: 88 T/A
https://www.thirdgen.org/techbb2/sho...threadid=202764
I know, I've been studying that post for what to do, but I didn't want to move my alt to the other side. I had to do this cheaply and quickly as this is my daily driver.
I still may pick up a delete pulley one day if I can get one cheap, but I refuse to go to the dealer to get one.
I'm also gonna keep my smog pump.
Old Oct 7, 2003 | 02:34 PM
www.gmpartsdirect.com
part # 10055890
that's where i got mine from for about 45 bucks shipped.
Old Oct 7, 2003 | 03:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
remove smog pump
flip direction the tensioner goes
run it on the tensioner.
that MIGHT work..... depends on the spring strength i suppose.
Old Oct 7, 2003 | 03:21 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I did that too except I got rid of the entire passenger side bracket and put on a short belt. It works great like this but I'm putting underdrive pullies on it soon so I may need another belt again. I like all the extra room it made.
Old Oct 7, 2003 | 08:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what did you use to tension the belt up?
Old Oct 7, 2003 | 10:35 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
No tensioner, I just did some grinding on the alternator bracket and made it adjustable.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
