My dumba** failed emissions!! Need some insight please.
Old Oct 20, 2003 | 05:56 PM
MdFormula350's Avatar
yup thats right my car sucked with hydrocarbons and carbon monoxide, hey but i did pass the fuel cap pressure test
State standards:
Hydrocarbons 220 PPM
Carbon Monoxide 1.20 PCT
My test:
398 PPM
1.36 PCT
slp 1 3/4 headers non air, no smog pump, no cats, slp catback, i turned my fans off and was running 220 temp at least when being tested.
maybe having cats right now would be a good thing, any cheap methods to get me to pass?
thanks for your help.
Old Oct 20, 2003 | 07:00 PM
johnsjj2's Avatar
Car: 1991 Z-28
Pay off the attendant?!?!?
Old Oct 20, 2003 | 08:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'd say just get cats, they don't hurt your performance THAT much.
Old Oct 20, 2003 | 09:34 PM
25THRSS's Avatar
yeap, get some cheap cats. Or if it's possible just pay the guy.
Old Oct 20, 2003 | 10:14 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Pay him off
Old Oct 20, 2003 | 11:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Run the ignition a bit more advanced. I've heard that helps.
Old Oct 21, 2003 | 08:46 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
no try and get the car to run lean and retarded. thats what we did to my car to help pass. also find some Dry gas , comes in a little weird lookin blue bottle with a white top, dump like 5 bottles in or use a bottle of rubbing alcohol. burns clean as hell.
Old Oct 21, 2003 | 07:18 PM
Bitchin89RS's Avatar
Car: '89 RS
Engine: LT4
MOVE TO TEXAS!!!!:rockon:
Old Oct 21, 2003 | 07:50 PM
EvilCartman's Avatar
Car: '82 Z28
Cats, it'll bring those numbers way down.
Old Oct 22, 2003 | 02:39 AM
ok i am going to go to the nearest exhaust place and see if they will weld something up where i can remove them when i want. i will just get the cheapest most restrivitive ones to block the bad stuff, and i will just plug the air tube nipples because i dont have those anymore.
thanks for the suggestions everyone.
Old Oct 23, 2003 | 07:55 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can get away with a 2-way cat if thats all they test for. NOX testing would require a 3-way cat (air)
-- Joe
Old Oct 23, 2003 | 08:42 AM
yeah the third one i think was nox but that was n/a so they dont test it, i will try on friday and get some cheap cats welded on to pass hopefully before it gets to cold out.
Old Oct 24, 2003 | 02:11 PM
bigals87z28's Avatar
Car: Check The Sig
run your car at 220 and above for at least 20 mins. My car was wayyyyyyyy below the numbers they listed, and that was in NJ. Get some Catco 3 way with AIR. Mine was like 60 shipped from summit. Its way better and you can keep it on for later.
Old Oct 24, 2003 | 11:32 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
DO NOT USE RUBBING ALCOHOL......its NOT the same type of alcohol that is used as a fuel......
fuel alcohol is ethanol or methanol...methanol is more common in racing and thats what we use in the truck....
certain types of dry gas are based on the correct type of alcohol and should work.
Old Oct 29, 2003 | 04:35 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
move to florida, no emissions here
Old Oct 29, 2003 | 09:12 PM
25THRSS's Avatar
you pass yet?
Old Oct 30, 2003 | 05:22 PM
lol didnt do anything yet, my next visit is free to try and pass, so i better do everything to make sure i will, i am looking around for some cheap cats right now and then back to my grandfathers house to borrow the welder.
Old Oct 30, 2003 | 07:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Hell yah, I dont know how Austin is, but back in CC, it was SIMPLE to pass....
Good luck with it..
Brady
Old Nov 8, 2003 | 11:32 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Catco cats are the cheapest. A cutout is a good option. Summit Cats
Old Nov 8, 2003 | 11:37 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No.. carsound is.. can get em new on ebay for under 35 bucks..
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33629&rd=1
94019 is the 3" 3-way cat..
-- Joe
Old Nov 9, 2003 | 11:09 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
383backinblack then i guess the guys ive seen pass with just rubbing alcohol got lucky then. i havent used it to pass, ive used Dry Gas to help me pass. but the rubbing alcohol is not that far off from the DryGas
Old Nov 10, 2003 | 07:11 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
100% isopropryl is fine.. 70% (rubbing alcohol) is not.. guess what the other 30% is??
-- Joe
Old Feb 15, 2004 | 01:31 PM
ok just wanted to let everyone know that i passed.
things i did before i went again.
pulled the airbox, so basically run open throttle body
reset the computer
had a full tank of 93, last time it was only half full.
and it was alittle warmer this time.
this time they gave me the idle test and no roller, i asked why the guy said the person last time couldnt handle it and get the right readings
anyway they put my car in the computer as "idle only" so i just go in and put it in park and they test the exhaust for like 2 minutes or so.
glad i didnt go out and get cats and waste money.
the carbon monoxide levels read alot lower, but the hydrocarbons stayed alittle high i passed by being 1 number lower i call it close but i passed. hopefully next time i could maybe lower the fuel pressure and take timing out even more from stock.
Old Feb 15, 2004 | 03:01 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
I ran my car for about an hour and bought RXP, poured it in the tank, and passed. This was after I failed the first time around.
Gunner242
Dec 25, 2015 04:49 PM
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
