Home Port and Polish Job
Old Nov 17, 2003 | 06:20 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I call the machine shop and they wanted $450.00 to port and polish these heads that I have on a 283. I was not about to spend that much money on a engine that I will only use until next spring.
Well I took a liitle time this week end and done the port and polishing job on the heads. Check out the picture and let me know what you think. I could not get all the way in the intake runner but I got plenty of it.
Here is some before and after pictures.
http://f1.pg.photos.yahoo.com/ph/dtl...r=/461%20heads
Old Nov 17, 2003 | 10:12 AM
a73camaro's Avatar
It appears that you did not gasket match the ports.
Old Nov 17, 2003 | 11:15 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
I think it looks pretty good! Congratulations--you'll feel a real difference once they're buttoned onto the engine
Old Nov 23, 2003 | 06:24 AM
radiateu2's Avatar
You probably could have taken more out of the intake runners. I agree that it appears that you didnot gasket match your porting work.
Old Nov 23, 2003 | 02:27 PM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
As long as the head port is bigger than the intake port, gasket matching doesnt yield much if any of a gain. The heads look good, looks like the bowls/valve throats have been worked more than the runners. Many times the runners arent a restriction, removing material from them often adds a lot to port volume while contributing little or nothing to the flow potential.
Old Nov 24, 2003 | 01:00 AM
radiateu2's Avatar
I was actually referring to the exhaust ports. Most of the gains will be made by opening up the restrictive exhaust ports. Gasket matching is mostly important here since the gasket will become the restriction causing turbulance in the exhaust pattern. The most restrictive part of these heads are the small narrow exhaust ports. I agree that more can be gained by opening the exhaust ports is more beneficial than opening the intake side. On the intake side turbulance is a good thing it keeps the air and fuel mixed and atomized. Thats why we dont polish the intake side only the exhaust. On the intake side unshrouding the valves is more beneficial than cleaning out the runners. Valve shrouding in my opinion is the biggest bottle neck on the intake side.
Old Nov 24, 2003 | 09:08 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Don't try to hog out the exhaust ports either. That's not the way to make them flow well.
The trick is to concentrate on the high side of the port, smooth and blend the valve guide, and very lightly smooth the short side radius.
You can bring the roof of the port up a little, but try and keep it a smooth radius.
Don't think you'll gain a lot from grinding a lot off the short side because you won't. There's a dead flow pattern there and you want to keep it that way. If you make it flow too well it can cause the exhaust flow to come off that short side so fast, it will literally crash into the high side and cause turbulance. Not good. :nono:
Like the intake side, it's OK to have the exhaust port coming out of the heads a little smaller than the header tubes/manifold ports especially on the low/short side. It helps prevent reversion, which can also cause turbulence, poor mixture at low RPMs, and other things.
It actually looks like you're on the right path. It looks good.
Next set you do, try to get rid of the flat spot on the roof of the exhaust port where the valve guide sits up against it.
Try to make it look a little more like this.
Old Nov 24, 2003 | 09:20 AM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
People have actually had gains in exhaust flow by making the short side radius flat perpendicular to the valve seat, might be something to try as well.
Old Nov 24, 2003 | 09:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i just thought you or anyone else browsing thru there might want to look at this..
its kind of a beginners how to on porting.. http://www.sa-motorsports.com/portdiy/diyport.pdf
Old Nov 24, 2003 | 02:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is a great link. I have been searching for awhile for a great DIY porting guide. Thanks for the heads up MrDude.
Old Nov 24, 2003 | 04:09 PM
AJ_92RS's Avatar
Originally posted by formularpm
People have actually had gains in exhaust flow......
Would those be professionals, with access to flow benches and dynos?
Old Nov 24, 2003 | 04:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would say yes. But not necessarily professionals. From I read all the time small block heads typically are really restrictive on the exhaust side and can improve dramatically from just the simplest port job.
Old Nov 24, 2003 | 04:16 PM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
If you consider David Vizard a professional, then yes.
Old Nov 24, 2003 | 04:28 PM
AJ_92RS's Avatar
A-B conversation...
Exactly my point.
Unless you have access to a flow bench and dyno, don't mess where you don't now exactly what the results will be.
Old Nov 24, 2003 | 05:40 PM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
Thats probably the best advice you could give a novice porter. Id add a velocity probe to the list of essential tools, though.
Old Nov 24, 2003 | 07:28 PM
DTL504's Avatar
Here is a few more articles that I read:
http://www.ws6transam.org/ported.html
http://www.babcox.com/editorial/us/us110128.htm
Hotrodboba400
Dec 10, 2019 07:07 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
Ranbo108
Sep 9, 2015 12:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
