White parking lights.
Old Nov 19, 2003 | 09:43 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Has anyone put in white parking lamps on their camaros? If so do you have pics? I've developed a hatred for amber and want to get rid of as much as possible even if it is just light and not always seen.
Old Nov 19, 2003 | 10:58 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
yup
just changed the bulbs to superwhite.... easily done
Old Nov 20, 2003 | 02:32 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I used white LED's everywhere:
White LED's in:
Side Markers
Front Turn Signals
Aux in Fog Lights
Headlights
License Plate Lights
Back-up Lights
Red LED's in:
Brake Lights
Rear side "triangle"
Old Nov 20, 2003 | 02:45 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
I found an old pic with all the front LED's on;
EDIT: I've actually been thinking about changing the side markers and turn signals to a really deep orange like on the 4th Gens and C5 Vettes except still use LED's; I know a lot will say "you've got r!ce, change them to the amber!", but I do sometimes like the "flashy"ness of the white, so for now it stays.
Old Nov 20, 2003 | 07:43 AM
LUVmy92's Avatar
Car: Camaro
Where can you get those white LED's for the front turn lamps? Are they a replacemnt type bulb or custom wired?
Old Nov 20, 2003 | 06:01 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
eBay, http://www.autolumination.com, or some place local that does import stuff. The bulb is a 1157 for the front, and 194 for the sides. So you could just search for "white led 1157' on ebay and get at least a dozen results (similarly for the 194). The most I've seen is like a 19 LED 1157, and a 4 LED 194 (where more = brighter/better).
EDIT: Try to get 1157's with a diode.
Old Nov 20, 2003 | 06:20 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
A buddy of mine found 6-LED 194's in a variety of colors. I'm sure they are a little brighter than the 4-LED 194's.
Old Nov 20, 2003 | 07:43 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
http://www.superbrightleds.com
Old Nov 20, 2003 | 10:17 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Ah yeah, 30 LED 1156 and 1157
Old Nov 21, 2003 | 02:05 AM
bigals87z28's Avatar
Car: Check The Sig
TPIROC, do your lights come on fast like the Caddies? I was thinking about doing that to my car too.
Old Nov 21, 2003 | 03:20 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
The bulbs I used have diodes built in to simulate a load. Older turn signal systems rely on the load of the bulb to operate properly; so it flashes at no different speed than with the bulbs - the circuit is unchanged. If you got an un-loaded LED, it may blink faster, or not at all (or the same, really not sure).
Old Nov 21, 2003 | 03:52 AM
Car: Check The Sig
But an LED is a diode?
Old Nov 21, 2003 | 07:49 AM
LUVmy92's Avatar
Car: Camaro
Thanks for the info guys I have been looking for a way to make the front turn lamps stand out a bit more and I think the 30 LED's should do it! Now should I get amber or white?
Old Nov 21, 2003 | 09:54 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes (led=light emitting diode). He may have meant resistor to simulate the load a bulb would normally place on the flasher relay.
Old Nov 21, 2003 | 10:10 AM
Car: Check The Sig
thats what I thought...wasnt sure if he knew.
Pac J
May 17, 2020 10:44 AM
///DAN///
Sep 25, 2015 02:15 PM
KCG
Sep 23, 2015 09:05 AM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
