Front end sanding
Old Nov 30, 2003 | 10:46 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Front end sanding
I am working on a New Front End I got to make my sport coupe a little nicer lookin, and it has a few problems. Im sanding, and it has black paint on top of red, so i sanded the black off, but in some really chipped up areas, it seems lke the black is under the red too... Is there anything like bondo that I can use on urathane? I hear bondo itself is bad because it doesnt flex. Should I chemically strip it? If so what should i use?
Old Dec 1, 2003 | 12:21 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
whatever you do...don't do that!....that would eat the urethane for sure. I would keep sanding...but not with anything to harsh. If it has actual chips in the urethane....I guess you could try some glazing icing...I've done it before..I mixed it...then applied it with a razor blade on the little chips...it worked great..and I really didn't even have to sand the area down much because it filled the chip right in.
Old Dec 1, 2003 | 12:29 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
When I stripped the bumper cover on my RS I went at it with 80 grit on a DA and didn't look back.. Took about 2 hours to get it where I wanted it. Then I hit it with some 180 and then primered it with some primer-surfacer.
Kat
Old Dec 1, 2003 | 07:12 PM
Car: 95 Z28
Sorry for the crappy quality and the battery low thing, heh... but Here is what i did today, it seems a lot nicer. What is the best kinda filler to fill in deep chips ect? So there isnt some kind of urethane safe paint stripper? lol
Old Dec 2, 2003 | 09:00 PM
kakarot's Avatar
Car: 1986 IROC , 1987 IROC (Kid's car)
Engine: 305 4bbl, 305 TPI
Transmission: T-5, 700R4
3M makes a 2 part epoxy just for fixing parts like this. I just usedit to fix a huge tear in the center of my son's chin spoiler on his 87 iroc. You just mix the epoxy and apply like any body filler and sand it down in stages. Should be available at your paint supplier. Works like a charm.
Old Dec 2, 2003 | 09:19 PM
Car: 95 Z28
Is there any point in primering it? Also it has the GFX that goes along it and to the fenders, I hate my current nose, and I feel like puttin this one one soon. It would look wierd with no GFX because bolt holes along the bottom, but With it would look wierd, anyone have opinions on that
Old Dec 3, 2003 | 08:56 AM
kakarot's Avatar
Once you have fixed it you'll want to primer it and make sure to use flex additive in your primer then block it down like any other part..
Old Dec 5, 2003 | 04:55 PM
fyrechikyn's Avatar
3m makes a flexible poly putty especially for plastic parts as far as bondo n
Old Dec 5, 2003 | 04:57 PM
fyrechikyn's Avatar
not flexing ive seen fenders crunched like an accordion with bondo on them and the bondo stuck to the panel and bent with it and never break. alot of it has to do with how thick you apply it ..............sorry about the double post i hit the wrong button on accident
Old Dec 13, 2003 | 07:12 PM
Car: 95 Z28
Tonight I finally applied my first coat of paint! I need more layers to cover up the marks
Between Layers I sand with 400 Grit dont I? Wetsanding is just gettin it wet with plain water and sanding correct? Is that what I gotta do? Still wet in those pics BTW, lol
Old Dec 14, 2003 | 12:18 AM
stiers's Avatar
I think you forgot to use primer....
Old Dec 14, 2003 | 12:30 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
No kidding...
With translucent (sp?)/opaque (metallic) paints, the base color or primer has to be a solid,uniform color or else you'll need 600 coats of paint to make the 'color' thick enough to hide what's under it.
Old Dec 16, 2003 | 10:32 PM
Car: 95 Z28
ITS DONE!!! lol... It looks just like I had imagined. Tomorrow I am putting it on, and I will link pics then too
Before, the day I bought it:
and tonight
and
Cant wait till its on :hail: :hail: :hail:
Old Dec 18, 2003 | 06:14 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
looks alot nicer than it did before.
Old Dec 18, 2003 | 04:19 PM
Car: 95 Z28
thanks ,lol... Here is a link to the page about puttin it on, lol
http://s89706284.onlinehome.us/new/index.html
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
